Question about Annovi Reverberi Garden
Pump rebuild kit
Pump siezes
2 Suggested Answers
spraydoctor
  • 97 Answers
SOURCE: how to rebuild the pump
Kit 1857 is the water pressure seal kit. 1856 is the piston oil seal kit. The head of the pump has to be removed first. There are 6 bolts, most likely "allen head". After they are removed, the manifold head will separate from the crank-case (the part with all the mechanical bits). With the inside of the manifold head facing up, you will see 3 chambers (or holes) where the pistons do their work.
Inside of these chambers is where the packing seals and seal retainers live. The seal retainers are made of brass usually--could be a different allow on the XRA, but that doesn't matter. The point is that there are, in each chamber, one or two metallic retainer pieces that help to hold the pressure seals in place. These may pull out easily -- but often don't. I always use a tool called a slide-hammer. It has "fingers" that reach into the holes and mechanically expand, grabbing the retainers, and then the hammer part pops them right out. You can get creative and find a way to remove the retainers -- perhaps with two screw drivers, crossed like an X, and wobble to and fro while applying up pressure. I've done this when I couldn't find my slide-hammer. (They fit tightly, but are not pressed in.)
The most useful thing that I can tell you is to go slow and observe methodically. Keep things in order as you pull them out. Every pump is different, but typically, the first new piece that goes back into the pump head is a rather rigid feeling piece that has to be pressed into place (this piece may actually have an accompanying supportive piece that would go before it -- a hard black plastic ring that ends up supporting the "V" shape of the pressure seal). When I say "rigid", I don't mean as in metallic. It is more like a reinforced piece of hard, brown plasteen polymer. This is the High Pressure Seal. The "V" should be upside-down (if the head is laying on a workbench with the chambers/holes facing up). In other words, from your perspective, the cup is upside-down.
Now press it in with your thumbs. It is helpful to use a little oil on this seal to make the edges slick -- I press them in with my thumbs. Fingers are not strong enough to press them into place, but thumbs are -- just to give you an impression of the necessary force involved. Remember, this part is not metallic, so don't try to push it straight in, but let it tilt such that one side pushes in, and then it starts to wrap around, pushing in as it progresses around.
On most of these pumps, manufactured by the Annovi Reverberi Company, there is another seal that serves as a Low Pressure Seal. This one is quite different. It is much softer and made out of a rubber polymer. This one goes inside the outer-most metallic packing retainer. I generally remove the old one with a dental tool or small needle-nose pliers. It should wind up with the "cup" side down (just like the high pressure seal). As you rebuild each chamber with the new V-Packing Pressure Seals; after each metallic piece is inserted (with the help of oil to lubricate), tap it down gently with a 19mm (or so) socket and something light for a hammer (like a small crescent wrench). Just a little -- to be sure it is seated.
The next kit (1856) is Piston-Rod Oil Seals. If the pump is leaking oil, by all means, replace the old ones. If it is not, don't do it! Old oil seals are hard to remove without scratching the seats they sit in.
To remove old oil seals -- The ceramic pistons have to come off first. These pistons are easy to damage, so be careful. (As a side note, your pistons could be damaged already. They can crack under certain conditions.) After the pistons are out of the way, then you can use a dental pick or similar small/hooked tool to pull them out. They are usually made out of rubber with a steel washer in their core to add rigidity. Once the old ones are out, the new ones are simple to install. Just put them in the way the old ones were.
To put the pistons back on, clean the bolt threads and use some lock-tite. Tighten them to about 20 PSI, carefully (if you let your wrench lean sideways it could chip or crack the ceramic). Slather the pistons with oil before attempting to replace the manifold head. The new pressure seals will fit quite tightly over the pistons. Being careful to keep the head fairly straight, push it down over the pistons until it is far enough that the head bolts can reach the threads in the crank-case body. This way, you can use the bolts to pull the head the rest of the way on. Tighten each bolt just a little at the time such that the head is more or less pulled strait down (avoiding any severe tilting, which could damage the -- you guessed it -- ceramic pistons).
Tighten all head bolts, snugly. Remember, where the head and crank case body meet is NOT a water seal. It doesn't work that way. So there is no need tighten head bolts real tight.
And that, my friend, is that. I hope this helps you and please give me positive rating. Just shoot a note here if you have any further questions.
Don
Posted on Mar 03, 2012
I cannot turn my crankshaft pulley on my hummer h3
Bad, bad, and bad. You can try a large breaker bar with a really long cheater bar, like 6' long, as a last resort... but it sounds like the engine is locked up because the main bearings have failed and welded themselves onto the crankshaft. It only takes one siezed bearing to lock up an engine. You could conceivably drop the oilpan and see if you can find the siezed one and replace just it, but really an engine rebuild is in order. Don't forget a new oil pump. Sorry.
Sep 18, 2014 | Cars & Trucks
Need a rebuild kit for pump not motor
A O Smith does not make a Pump,
they make motors, so...
what pump do you have, so pump rebuild kit can be recommended?
Apr 13, 2014 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
No water pressure coming from pump
The pump is bad and needs to be replaced. you have done all the test. On the Briggs they do have kits to rebuild the pump on your system you can just go to there website and get the rebuild kit. It is safer to go through them because they have jsut started producing the rebuild kits, and other companies have tried to copy them, but there kits are worthless. Please rate
Jun 04, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Is there such a thing as a rebuild kit?
There is no 'rebuild kit' for the pump. Clean filter and, depending on your mechanical skills, remove pump and cover and cleans out any debris in pump impeller.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Beckett Water Gardening Garden
Bake breaks keep on locking and not releasing again i have changed the calliper but problem still the same
brake caliper is siezed from lack of use, will need caliper rebuild kit, but if you have to just wheel it around to tap the caliper with a hammer lightly it will loosen it up so it can be moved
Jul 16, 2009 | Honda CB 750 Motorcycles
Rebuild kit for the Aquascape SFA3000 Pump???
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Jun 18, 2009 | Ultra Max Aquascape AquaBasin, Pond or...
Need a diagram how rebuild kit (o-rings & seals) go in pump
go to your local libary and check for a workshop manual on your make and model it is quite an intense job
Apr 25, 2009 | 1994 Ford Tempo
Crosman model 200 rebuild kit for the pump
You can order a crosman rebuild kit from:
Bryan and Associates
Anderson, SC
1-864-261-6810
Feb 08, 2009 | Crosman ® Quest cal. Air Rifle with 4x32...
Garden Logo
Top Annovi Reverberi Garden Experts
Bill Boyd
Daryl Gleaton
fasteddy
fasteddy
Level 1 Expert
Are you an Annovi Reverberi Garden Expert? Answer questions, earn points and help others
