Question about Samsung Ultra SlimFit 20" Digital TV
Samsung slim fit tv
I mistakenly moved the extension box which the TV is connected to, and it went off. When I tried to put on the TV, it didn't respond; but the extension box is still working fine.
SOURCE: Zapping sound when turn on
Same buzzing sound here...help!!!!!!!!!!!!!!
Posted on May 10, 2008
SOURCE: no power, picture or sound
Contacted Sears and they are sending a Samsung Tech to fix my TV. Others had no luck getting a response. Sears did not argue about Warranty.
Posted on Jul 10, 2008
SOURCE: my samsung slim fit tv has a horizontal line which
cordless phone base was too close and was giving interference to the television moved away and solved
Posted on Sep 21, 2009
barbu51
  • 566 Answers
SOURCE: cant use TV as Computer display
If you can disable the blue screen via the tv menu you might see something happening behind that blue ,you might be able to figure it out from there, also try to connect as directly as possible (tv/computer) even if you have to physically move one or the other, that way you can eliminate possible problems. good luck
Posted on Nov 03, 2009
dmathur62
  • 45 Answers
SOURCE: The color on my Samsung Slim Fit TV suddenly
This line shows that there is failure of vertical output stage,may be due to high supply from internal power supply of TV set,check the voltage of the vertical output stage,and after rectification of supply problem replace vertical output IC to get this problem solved.
Posted on Feb 08, 2011
A circuit was out,which included tv and frig, moved frig everything went back on! what happened?
If the whole house power wasn't down, then you could have a circuit breaker that is flaky or a wire connection in the breaker panel or at one of the outlet boxes along the way from the panel to your outlets. If it happened once, it will happen again. I'd cycle the power at the breaker, just on general principles to make sure the movable components within the breaker are where they are supposed to be. If it happens again, I'd start at the breaker and check every outlet box in that circuit for a loose connection, either a screw or wirenut. Breakers aren't expensive to replace if you can't find any loose connections along the way.
Apr 15, 2014 | Samsung Refrigerators
Lg 50pm4700 will not connet to the internet
I had a similiar problem and found a solution! :) im passing on my joy to you. Try getting a USB extension or just wrapping foil around the Dongle. It seems that the dongle or the TV causes interference of some sort to cause the tv to drop the internet. ON my tv it would say connected to the net sometimes but as soon as id try netcast it would drop. As soon as i got the extension it went away. At least try the foil thing. Wrap it like a Dog cone for injured dogs.
Jul 14, 2012 | LG ANWF100 Wireless dongle
No sound coming from my Vizio Model #E320VL HDTV. Tried everything I can think of. I have Direct TV and it just stopped working one day. Any advice?
We just had the same problem with our tv, we switched tv's and it still didn't work. We reset our att uverse box, and the sound works. I don't know how direct TV works, but the problem may lie there instead of your TV
Sep 09, 2011 | Vizio VF550M 55 in. LCD HDTV
Have a PS3 slim, when i turn it on at connect it to the TV with the Component cables, everything works fine, picture shows and the sound comes out just fine, but when i try to connect it with the HDMI...
You need to turn on the tv and set to HDMI, Then power on the PS3 and hold down the on (standby) button until it beeps again twice and it will pick up the TV and display on the HDMI,
If this doesnt work go to system settings and video settings and set the output to HDMI.
Anthony
Jul 21, 2011 | Sony Playstation 3 (PS3) Console
I have a sylvania srt2319 tv which has never had any problems. just recently we got directv and they put the dvr box into the antenna hook up in the back. now the tv keeps going back and forth to a thin...
Your TV has bad solder connections at the set's verical output integrated circuit. It's very common for these connections to go bad because of heat from the part. When the technician moved the set around to hook up your new box, it may have jarred the connections enough to finally cause the existing problem to become more obvious, but he didn't cause the problem. Your set would probably be doing this anyway before long. The good news is that it's just a simple fix. Resoldering the connections should restore normal operation.
Jul 15, 2011 | Sylvania SRT2319 TV
My child had her remot to her disney tv ad thevolume went out. I want to know wats wrong with tv. I tried everything and volume won't comeback on.
Check if you mistakenly hot the mute button. If not check other remotes, i.e cable, set top box remote volume. Thumb me up if I helped. :)
Jul 02, 2011 | Disney DT1350-P 13" TV
Cant use TV as Computer display
Nov 03, 2009 | Samsung DynaFlat TX-P3064W 30" TV
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
I have ps2 slim connect with crt monitor through tv tuner box but
have you tried hooking the tv cords from the ps2 directly to the tv?
Mar 29, 2009 | Sony PlayStation 2 (PS2) Console
Samsung Ultra SlimFit 20" Digital TV Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
