Question about Belkin Wireless-G Plus MIMO Router with USB Adapter and Geek Squad Installation
HOW DO I INCREASE THE RAM ON MY EMACHINES E4252, I RUN WINDOWS VISTA ON 32 BIT SYSTEM
  • 828 Answers
The RAM just clips in. But be aware that there are many different types of RAM which either will not physically fit into your computer, or it may be incompatible.
Remove your RAM modules and look at them .. you will see (maybe..) a sticker with numbers on ..i.e PC2300 DDR2 .. whatever. Use ebay to search for a RAM supplier but do ask their advice about which RAM you can fit. Those guys are usually on the ball and very helpful and will supply the correct RAM for your particular motherboard.
Incidentally, Vista was never a good operating system. Too many problems with it. A lot of people reinstalled XP or upgraded to Windows 7
Posted on Jun 10, 2013
  • 58 Answers
Go here:
http://www.crucial.com/index.aspx
and let the system scan your PC.
It will recommend what you need.
Posted on Mar 15, 2009
2 Suggested Answers
SOURCE:
Joed911
  • 4338 Answers
SOURCE: RAM ON emachines E4252?
Yes....
Make sure that the power is off, and uplug the unit from the back. Then install the memory and plug it back in then power it back up. The computer will see the new memory and so will Vista.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 01, 2009
1 GB increase
hi
not every motherboard or on board video is compatible with windows 8
what windows was it running previously
windows 8 was designed for 64 bit platforms which requires 4 gig of ram but you have to also take into account the other hardware components and there maximum configuration
i have run win 8 on 2 gig of ram but it struggles with you tube downloads
i upgraded the ram to 4 gig and run win xp win 7 and win 8.1 on the hard drive
cheers
Apr 05, 2014 | E-Machines eMachines Desktop PC
Can it support windows 7
yes, its supported by windows 7.
but need more setting to make it fast. maybe tune up utility will help increase the performance.
help me by rate my answer.
Mar 06, 2011 | MSI K9MM-V Motherboard
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
Oct 15, 2010 | Dell Dimension 4700 PC Desktop
Windows 7
go to microsoft .com and do a compadibility check
Nov 24, 2009 | E-Machines eMachines Desktop PC
I have installed 4 GB of RAM but it only shows 3 GB RAM
Any 32bit OS can only read up to 3.5GB of RAM. In order to read additional ram you must have a 64BIT OS.
Sep 27, 2009 | Computers & Internet
Vista x32 want to upgrade vista x64
microsoft provides upgrade discs from it's site (you should payteh freight).
If u are using Microsoft Windows Vista Home Basic, there is no way to upgrading.
else, the other versions allows u to upgrade.
remember: the only difference between 32 and 64 bit is the RAM memory usage (32 bit will not use more than 3,2GB RAM), and there are a lot of programs that won't run properly in 64 bit version .
Jul 26, 2009 | Microsoft Windows Vista Home Basic with...
Diffrence
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. For more details, go to A description of the differences between 32-bit versions of Windows Vista and 64-bit versions of Windows Vista online.
Jul 24, 2009 | Computers & Internet
Vista RAM usage ?
The minimum recommended ram for Vista is 1 GB, generally accepted practical minimum is 2 GB. A 1 GB system will be kinda laggy. Maximum RAM for 32 bit Vista is 4 GB.
Vista Home Premium is roughly equivalent to Windows XP Media Center Edition (Has Media Center, cann't be put on a DOMAIN type network)
Vista Business is roughly equivalent to Windows XP Professional (Can Join a Domain, Doesn't have Media Center)
Vista Ultimate has all available freatures of Vista, you can do any windows function with Ultimate
Apr 26, 2009 | Dell Dimension 3100 PC Desktop
Does the MX 310 work with Vista
Looks like you will need to download a driver.
You'll need to know if you have Regular Vista or Vista 64-bit.
Here's how you can tell:
64-bit versions of Windows Vista are for computer users who have high-performance needs and are typically running a computer with 4 GB or more of Random Access Memory (RAM). The terms "32-bit" and "64-bit" refer to the way a computer's processor handles information. The 32-bit versions of the Windows operating system can only use up to 3 GB of memory.
The 64-bit versions of Windows can use more memory and help reduce time swapping processes in and out of memory by storing more of those processes in RAM rather than on the hard disk. This, in turn, can increase overall system and application performance, especially with applications optimized for 64-bit. For more details about 32-bit and 64-bit, see the Windows Help and How-to FAQ.
To find out what version of Windows Vista is installed on your computer:
  1. Click Start start.gif, click Control Panel, click System and Maintenance, and then click System.
  2. Under System, view the System type.
If you're running Windows XP:
  1. Click Start, click Control Panel, and then double-click System.
  2. On the General tab, view the System type.
Now you know your system type and can download the correct driver from this page:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603#DownloadDetailAct
Let me know if that works for you. Be sure to follow all the directions.
Mar 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Yes....
Mar 15, 2009 | Belkin Wireless-G Plus MIMO Router with...
Belkin Wireless-G Plus MIMO Router with USB Adapter and Geek Squad Installation Logo
15,082 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
