Question about Vtech Storio Animated Reading System Disney Fairies Software
Storio The storio won't turn on even if I change the batteries
My Vtech V-reader freezes on calibration screen
I just found a solution to this: Turn off the vreader, then press & hold the help "?" button. While holding the "?" button, press power. My system bypassed the calibration step and booted correctly.
Jan 05, 2012 | Vtech V.reader Reading System
Is there a reset button on a storio
There isn't a reset button for the Storio.
If you need to erase all of your child's saved drawings, etc. the Storio can only be reset by reinstalling the software. You'll need an SD card with at least 64mo of memory. The Recovery program will erase anything that was on the SD card, so transfer anything you want to keep tp your computer. Download and run the Recover SD card creator program from one of the links below:
For the US version
http://contentcdn.vtechda.com/vtechkidsDownload/US/VReader/Tool/Recover/US-engRecoverCardTool.exe
For the Canadian english version
http://contentcdn.vtechda.com/vtechkidsDownload/CA-eng/VReader/Tool/Recover/CA-engRecoverCardTool.exe
This is the link the the website itself:
http://www.vtechkids.com/download/ca/en
Follow the steps to reinstall everything. It takes a few minutes.
Dec 31, 2011 | Vtech V.reader Animated E-book System
How do i fix my vtech storio the screen is just blue and it wont work ?
The blue screen seems to happen when you change the batteries (it's what happened to us). The blue screen indicates that there's a software problem, like when you boot up your computer and for some reason it freezes up. That software needs to be reinstalled. You'll lose anything that was saved on the Storio, but at least you'll get it working again.
vtech could have made it a very simple problem to solve just by adding in their customer support: Blue Screen? follow these steps. But they don't, so here's how:
You'll need an SD card with at least 64mo of free space. If you want to use the one from your camera, transfert all of your pictures to the computer. Everything on the SD card will be erased.
Download the Recovery software from either link below (you can find both on the vtech website, but it took me a while to get there)
For the US version
This is the link to the website itself:
Run the program and follow the instructions (at least those are clear and easy to follow). Mine worked fine after that. And since there's no reset button on the Storio, this is the only way to erase the 100+ drawings that your child saved.
Hope that helps
Dec 17, 2011 | Lands Phones
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
My logitech wireless usb mouse will not turn on at all. I have even changed the battery and still wont turn on. i made sure the batteries were in correctly and i just wont turn on. I was using it and it...
I'm having the same problem, connecting isn't the problem, its just that the mouse won't even respond to the batteries being put in. Bought fresh new batteries, still no luck :\
Sep 25, 2009 | Logitech Cordless Mouse
Vtech Storio Animated Reading System Disney Fairies Software Logo
70 people viewed this question
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
