Question about Honeywell Home Security
One of the keypads is sounding
We have a Honeywell K4392V2-H M7240 keypad that is producing a steady loud ring. What do we need to do to reset the system?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Try powering it down and reseting
Posted on Dec 18, 2014
SOURCE: garage door keypad code. How do I reset it?
http://download.sears.com/own/53985e.pdf
try this website page 36
Posted on Aug 13, 2008
  • 3197 Answers
SOURCE: garage door opener keypad
On the rear of the opener near where all those white wires go you will find the smart/learn button. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you want and press enter. Should do it for you.
Posted on Jun 29, 2009
  • 3197 Answers
SOURCE: How do I reset my keypads outside? My battery
There is no reset. You can try programming it and see if that works. If not it is probably dead.
On the rear of the motor unit you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in your four digit code and press enter.
Posted on Oct 24, 2009
jhinsincity
  • 616 Answers
SOURCE: Garage door external keypad staring to fail regularly
replace the pad, it is exposed to the enviroment, try to find a box of some type to protect the new one.
Posted on Dec 10, 2009
  • 3197 Answers
SOURCE: keypad won't program to garage
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
Posted on Oct 03, 2010
Honeywell ADEMCO 6150RF keypad sporadic constant beeping
It is trying to indicate a problem with zone 1. check it out.
Jul 25, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
HOW TO CHANGE THE BATTERY IN HONEYWELL ALPHA 6160 KEYPAD
There is no battery in the Honeywell 6160 keypad. It is powered by the transformer in the control panel. If it is showing BAT on the keypad, check the main system battery in the control panel.
Feb 28, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
I think i have a vista keypad. I dont have a manual that shows the keypad features. I like for the doors to chime when opened. They stopped chiming for some reason. can this be reset.
On a vista system, enter your 4 digit code and press the 9 button. The keypad should read: Disarmed Chime. The keypad should ding ding ding when a door is opened. To turn the chime off, enter you code and press the 9 button again.
Jun 18, 2011 | Honeywell 6160 Vista Custom Alpha Keypad
My precor efx 546 keypad comes on, the enter button accepts all the info and programs are displayed. 1. The quickstart button does not work. 2. Both crossramp and resistance do not move either when...
1. Sounds like you need a new keypad if some buttons do not work. 2. If those buttons do not work either, it sounds like you need a new keypad, possibly the upper board. Make sure the keypad is plugged into the upper board and the connection is not corroded. 3. Older 546s used an electromagnet to produce resistance, newer 546s use a generator and resistor to produce resistance. I have never seen a 546 that used a motor that moves back and forth to produce resistance. Some residential crosstrainers use a motor like you describe.
Mar 10, 2011 | Precor EFX 546i Elliptical Version 4
Manual for a Honeywell K4392V2 M6983 RevB to solve ''BAT'' display
Check to see if you have a wireless remote that requires a battery, mine when bad and it was the wireless remote to turn on and off from outside.
Jan 23, 2010 | Honeywell Humidifiers
Sound Settings Problem
press menu, select setting, Ring style,
on ring style you can see
Style: loud, soft,vibe, vibe and ring, silent....
if you select loud you can see this if you open ring style
Style:Loud
Loud Details
just select loud details and scroll and select' key volume
and you can now off by pressing down the scroll botton until it become zero.
thanks for rating this solutions....:D
Apr 09, 2008 | Motorola Mobility RAZR V3
Key pad sound
open ur phone menu first. then go to settings,open settings, then select ring styles,then select second option it can be as ??????detail.(???? = type of ring style u have selected,whther it is loud, soft, vibrating .vibe & ring or silent). just select second option,then scroll down and look for key tone type, select it and choose it as off, ur annoying keypad will silent. thanks best of luck.
Feb 24, 2008 | Motorola Mobility W375 Cellular Phone
Home Security Logo
158 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
