Question about Pyramid Car Audio & Video
Installin av jacks
How to install jacks from amplifier to stereo deck?
2 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: I have a sony explod car stereo without rca jacks
INPUT:
SCOSCHE FAI-3A - SONY XPLOD HEADUNIT
A1 - Grey (Right Front +)
A2 - Grey/Black (Right Front -)
A3 - White (Left Front +)
A4 - White/Black (Left Front -)
A5 - Green (Left Rear +)
A6 - Green/Black (Left Rear -)
A7 - Violet (Right Rear +)
A8 - Violet/Black (Right Rear -)
OUTPUT:
SCOSCHE FAI-3A - AMPLIFIER
B1 - Right Front + (Not Used if using RCA)
B2 - Right Front - (Not Used if using RCA)
B3 - Left Front + (Not Used if using RCA)
B4 - Left Front - (Not Used if using RCA)
B5 - Left Rear + (Not Used if using RCA)
B6 - Left Rear - (Not Used if using RCA)
B7 - Right Rear + (Not Used if using RCA)
B8 - Right Rear - (Not Used if using RCA)
Right Rear Output - REAR RCA IN (White)
Left Rear Output - REAR RCA IN (Red)
Right Front Output - FRONT RCA IN (Red)
Left Front Output - FRONT RCA IN (White)
Note: Be sure to connect the Remote Turn-On from the Sony Xplod (Blue/White) to the Amplifier's Remote Terminal. All that's left is to connect the 12-volt power wire to the Amplifier's Power Terminal and a Ground wire to the Amplifier's Ground Terminal. Also, switch the FAI-3A to Line Out using the switch on the left side of the device, and ground the FAI-3A using the device's ground wire.
If you need any more help, let me know.
Posted on Jun 08, 2011
How can i hook up my kenwood stereo control amplifier KC-105 to my GPX home stereo system?
If the GPX has an headphone output you could use the a stereo headphone jack to two phono cables lead. Connect them to the "aux" socket of the amp, or another suitable - not a phono or deck - socket.
You would have to keep the volume level low on the GPX unit, but apart from that all the functions should work.
Aug 04, 2015 | Kenwood Audio Players & Recorders
Trying to set up just the amp & tapedeck of the Sony TA-AX335 integrated stereo system, but can't get the ribbon power cord to work.
Does the deck light-up at all, or is it completely dead? I've found that in aging tape decks, the belts will deteriorate, and change into tar. I've repaired several of the TA series Sony systems, and that's usually the case. If the deck is just 'dead,' I would recommend retrofitting standard RCA jacks on the back of the amplifier. The pins on the ribbon cable are clearly marked on the PC board inside the amp. Then, you could use any deck you want, or even a CD recorder. Hope this helps. :)
Apr 13, 2013 | Audio Players & Recorders
How do you hook up a sharp stereo cassette deck RT-W800
If that tape deck of yours has an audio line out jack (like the RCA red & white holes, usually located at the back), get an RCA plug to connect it to your stereo receiver's line in jack..... or
if that tape deck of yours doesn't have an audio line out jack but, instead, has phones (or headphones) jack (usually located at the side or front of the unit), then get a plug to connect it to your receiver's audio line in jack (RCA type, also coloured red & white).. Usually the plug is small so you may have to use an adapter for your tape deck's phones jack.
BOB (June 23rd '12 3:45am)
Apr 28, 2012 | Audio Players & Recorders
Jvc KW-AV50 subwoofer amp hook up
very good ! there is nothig wrong with your system, buy a stereo to mono RCA jack (Rs10/-) and connect the subwoofer (if single coiled) L+ & R-- of your existing amplifier. NB: Please go through the manual of amplifier
Apr 08, 2012 | Car Audio & Video
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
I'm installing an aftermarket radio in my 2003 avalanche with a GMOS-04 interface. It has two sets of RCA lines, however my radio only has one set of RCA cables. I'm only getting sound from the rear...
If the stereo you are using only has one set of outputs for the rear you will have to get an auxiliary AV adapter for the front speakers that has an AV jack on it so you can use the AV jacks for the front as well. This is not hard and not expensive but it is necessary. The adapter you buy will depend on the radio you are using as it will plug right up to your radio. So I am posting a link to a place I use and you can choose the adapter you need based on your radio. http://www.crutchfield.com/S-ZimO2BBIZ8j/g_50900/Auxiliary-Input-Adapters.html
Mar 23, 2011 | Interface 4 Amplified Gm Systems
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
Do you have any manuals as to how to hook this up to a sony str av-710 receiver?
Well, since the EQ-0100 is a stereo analog component you will be able to use it only for stereo analog source material. Of course, once it's inside the av-710, you can manipulate the sound digitally for soundfield and such.
Basically, hook it in like a tape deck, say, in Tape Deck 2's circuit. Then, whenever you want to use it inline with stereo source material just select Tape 2 Monitor and it will be placed inline. Be advised, any digital programming you want to hear will probably be muted if you monitor any tape deck. That's pretty much normal.
You can slave an analog deck off the EQ as it has a Tape Record/Monitor loops of its own and facilities for making the EQ be on the Record OR the Playack side of it.
Normally, the receiver's internal volume, eq or effects controls will not affect the analog loop out to the EQ-100 or attached decks, BUT, this receiver sends processed effects out to Tape Deck 2, if you should desire to record them (page 29 of the manual). Other REC Out jacks pass conventional UNprocessed sound.
I couldn't find the exact instructions for this model but they all work about the same.
Nov 16, 2009 | AudioSource EQ-100 Home Equalizer
Need to know the wires to install a deck for 97
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
Sep 02, 2009 | 1995 Toyota Celica
How to connect phono leads
  1. Step 1 Check the back of your Stereo for recording input(in) and output (out), your cassette deck may be plugged into these jacks.
  2. Step 2 Connect the RCA/Phono wires to your equalizer's input and output jacks on the back.
  3. Step 3 If your cassette deck or some other component is plugged into the recording jacks in the back of your amplifier, unplug it and plug it into the back of the equalizer under monitor jacks. Be sure that the "out" from the cassette deck goes to the "in" of the equalizer.
  4. Step 4 Now, take the wires from the equalizer and plug them into the amplifier in the same manner: "in" to "out" and visa versa.
  5. Step 5 Once all your wires are connected be sure the "tape monitor button" on the amplifier is on. Turning it off will disable the equalizer. You can still monitor your recording devise or cassette deck by the "monitor switch" on the equalizer.
Mar 12, 2009 | Audio Players & Recorders
Car Audio & Video Logo
15 people viewed this question
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
