Question about Cobra NavOne 3000 GPS Receiver
Cobra server error - Cobra NavOne 3000 GPS Receiver
Name some popular Conquer Online Private Servers?
Name of some of the most trusted and popular top ranked private servers of conquer online are mentioned below:
a. Apex Conquer
b. Mr_Memo.com
c. Frozen Conquer online
d. Jade Online
e. ConQuerX Classic Server
f. Cobra Conquer
g. The best Conquer server of all. EXP x250, and much more.
To join any of these popular private servers, you can visit mu online private server .
Aug 03, 2017 | Online Computers & Internet
How is it repaired error E-29?
Search Results
    Motorola Spectra FAIL and ERROR Codes
    www.repeater-builder.com/motorola/spectra/spectra-error-codes.html
    Dec 27, 2007 - Motorola Spectra FAIL and ERROR Codes. ... For example, a radioFAIL code may look like this: "FAIL 01/90", where the first two digits ("xx" in the ....FAIL 10/84, Trunking EEPROM blank, Troubleshoot Trunking Option, CB.
    [PDF]How to Use Your Cobra 29 LTD Classic - Cobra Electronics
    https://www.cobra.com/sites/.../manuals/29LTDCLA.pd...
    Cobra ElectronicsBefore installing the CB radio, .... Even though the Cobra 29 LTD Classic has an automatic noise ...... referring to the manual, you still need help, call Cobra ...
Jan 13, 2016 | Radio Communications
Anyone else getting server error on Cobra Homebase when opening it?
Had the same issue. After weeks, and 2 calls to Cobra later w/o success, it clicked in my head...router firewall!
Temporarily change your firewall settings to minimum security and you should see the server error disappear and server available show up in Cobra HomeBase. Download what you wish to update and then reset your router firewall to the security level you had it on originally.
-Mike
May 04, 2015 | Cobra GPS
Trying to map update new cobra 6500
1- You need to install cobras update software which is available at their website.
2- Seem to remember that you had to register the unit with cobra otherwise the software would never work. (Might be in error on that though)
Once that is done it should update with no problem.
Jan 31, 2014 | Cobra NavOne 4500 GPS Receiver
Map udate for cobra gps server error
Are you using the Cobra HomeBase software? You can download it from the link below Cobra HomeBase If you are using the software, it sounds like there was a temporary problem with the servers Cobra uses. Try update again.
Jan 23, 2014 | Cobra GPS
HWK UPDATE
Originally Posted by MIRYALA SRINIVAS viewpost.gifhwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.
dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Jul 25, 2012 | Computers & Internet
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply
Sep 01, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Cobra radar detector xrs-989 manual
www.cobra.com then support then downloads then radar detectors.
Problem at the moment is Cobra is working on their server and the pdf is unaccessible right now, however, this is the link. Hope this helps
Jun 19, 2009 | Cobra Vehicle Parts & Accessories
Cobra 29 ltd when powered up error Y can anyone help me
Hi and welcome to FixYa,
Often an error code "Y" would indicate test/diagnostic result of the antenna. A communication equipment thus equipped would test the SWR and display this error code if:
  • no antenna detected; or
  • SWR of antenna is way too high.
Although am not familiar with the version of a Cobra 29LTD with this type of display. Could you pls post back the exact model of the radio, normally there would be two (2) more letters after the LTD something like Cobra 29LTD BT.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Cobra 29 LTD CB Radio
Cobra NavOne 3000 GPS Receiver Logo
297 people viewed this question
Top Cobra GPS Experts
Steve
ray gallant
Are you a Cobra GPS Expert? Answer questions, earn points and help others
