Question about Frigidaire FGX831C Top Load Stacked Washer / Dryer
Dryer marks clothes
White things come out of the dryer with rusty marks on them. They appear to have entered the gap between the mouth of the drum and the chassis of the dryer. The furry material on the chassis side of the gap seems to contain the staining substance. When I push a white cloth in the gap and turn the drum, it gets marked. How can I fix this? Thanks!
  • sidtupper Aug 26, 2007
    Thanks for the advice. It was just what I needed to motivate me to get serious and fix it. When I had the front housing off I saw that the felt was saturated with rust powder, which was staining the clothes. Also, only one of the three teflon bearing surfaces was left. I replaced that part and also the longer felt strip that goes the rest of the way around the bearing surface, about $50 in total. The instruction sheet that came with the part said that the bearing surface should be painted but it was polished steel; I guess the paint wore off when the teflon pads fell off. I hope that's not a problem, ie, more rust. Then I'll have to replace the whole front housing. Another thing I'm not happy about is part (20%?) of each revolution of the drum sounds different from the other part, not a steady hum. Not sure why.
  • 625 Answers
It could be the adhesive that holds the felt bearings on the front housing. you see the back of the dryer drum has a bearing in its center, the front of the drum rotates on two or more felt pads or bearings in/on the front cover where your door is. you'll need to remove the front cover to replace these felt bearings. there should be two screws, maybe more holding the front cabinet to the rest of the dryer. the bearings will be mounted to the front cabinet right around the hole for the door.
Posted on Aug 23, 2007
I have the calypso dryer that leaves random brown streaks on our clothes. Any suggestions
Something like this happens when one of the drum supports wears down leaving a gap between the drum & bulkhead. Clothes can get caught-up in this gap & this will cause the brown marks you see on your clothes. Open the dryer door & look around the front & rear perimeter of the drum, if you can see a gap I recommend replacing the drum rollers. If you aren't comfortable making the repair yourself, you can contact a local appliance repair shop or the manufacturer of your Calypso dryer.
Sep 28, 2017 | Dryers
When I take my clothes out of the dryer some of them have blackish marks on them please help thanks
Make sure the drum is properly seated. If the drum sags, clothes can get caught in the gap on the bottom, then pinched when the gap closes on the top. This can cause grease stains on the clothes, or worse, can tear them.
If the drum sags, check the drive belt and drum support rollers.
Sep 13, 2013 | Whirlpool AWZ7303 Electric Dryer
I have a whirlpool wed5520sq0 dryer the drum seems to be pinching cloths and making marks on them. The drum has a gap on left side looking into the dryer. I can move it and close the gap. Any ideas would...
Sounds to me like either the seals on the front and back of the drum are worn or the glides for the drum are worn and is causing the clothes to get caught between the drum and the usually the
front edge of the dryer. The worn glides will cause the gap that you mention.
Feb 11, 2011 | Whirlpool WED9200SQ Electric Dryer
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Dryer leaves brown spots on clothing articles. Suspect back seals as gaps are evident and drum is loose within the unit. What is remedy? Cost of seal replacement?? Kenmore 62802 Electric Dryer Deb in Brown...
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
Mar 23, 2009 | Kenmore Dryers
Moffat heavey Duty Dryer
Hi and thank you for your request.
Assuming the marks were not there before you put them in the dryer, then there are a couple of possibilities for the marks appearing.
Check that none of the clothes lifters or ribs as they are sometimes called in the drum are not loose, as the clothes could get caught in any gaps,make sure that there is no large gap between the drum front and the front of the dryer, as again clothes could get caught here,,check to see nothing is stuck on the drum itself that could transfer onto the clothes.
Make sure the drum is free to turn and that there is no unusual noise coming from it, if it does appear to be noisier than usual ,then it could be the drum rollers or bearings are starting to wear and this could transfer grease and the like onto your clothes.
Hope these suggestions help with your prob.
Plz feel free to leave any comments and rate my suggestions.
Thanks
Jan 05, 2009 | Dryers
Rear drum gasket is rust colored and marking the clothes
hi thanks for the question that part is the rear drum felt that is there to prevent articles of clothing from falling out of the drum this must be replaced thanks the appliance doc
Apr 06, 2008 | Estate TEDS740JQ Electric Dryer
Dryer is leaving brown streaks on cotton clothes
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Open Questions:
Frigidaire FGX831C Top Load Stacked Washer / Dryer Logo
213 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
