FixYa.com
Tags:
BenQ FP731 - 17
Benq FP731 17" monitor goes Blank after start up (by 3 users)
posted by mateen on Aug 09, 2007
Hi, As soon as I turm my Benq FP731 17" monitor, "Benq" appers for short time then it goes blank, Can any body help me on that.
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by dragon11351, posted on Jul 24, 2008
benq appears, goes to black screen, windowsxp splash screen appears and goes blank with black screen. turned monitor on and off, many times, sometimes monitor will work, sometimes not.
Comment by Guest, posted on Mar 08, 2008
I Have Benq FP371 LCD and the failure is No Picture at all only power botton was green.
I disassymbled the LCD and found one bad transistor P/N C5707 and I already replace a set Four (4) transistors which controls the inverters...
When I turned the on/off switch on, the back light flashes on the screen for a spit second.
I measured the high tension to the lamps, it is also noticable for a split second.
I checked all the transistors on the perimeter, they are all OK.
Do you have any more suggestions to solve my problem?
Kind Regards
Bram
Best Solution
posted on Sep 03, 2007
Thanks for Trying (70)
Kerind
Rank:Apprentice Apprentice
Rating: 75%, 5 votes
The only solution I've been able to find for this is to turn off the computer for a minute or two and reboot, while rebooting, it is important to keep the mouse moving so the arrow on the screen moves. This should provide a temporary fix, I'm unsure about a permanent one.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Monitors
Faulty backlights
What can I do to repair my... Answer This...
Monitors
off/on switch
When computer has been off and... Answer This...
Monitors
My Computer Screen
After my computer hibernates... Answer This...
Monitors
BENQ FP937s problem
Hi, I have exactly the same... Answer This...
Monitors
icemaker
i emptied the ice bucket and... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
