Question about Hayward H-series Electronic Gas Pool Heater H400
Hayward H-Series Not heating water
Hi, I have a Hayward H-Series Pool water heater. Symptoms; - The water is not heating up or heating very little. - There is no error code. - I think the air coming out of the top of the unit is hotter than usual. Any ideas would be appreciated, Thanks
    Top Expert:
  • Hayward Master
  • 6,498 Answers
If all burners are working correctly then put a bypass on heater plumbing open it half way to slow down water flow that will give you a higher heat rise
Posted on Mar 19, 2016
  • 5 Answers
SOURCE: Error code LO
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
Posted on Jun 07, 2009
john224
  • 1378 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
Posted on Jun 12, 2009
SOURCE: Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Posted on Sep 16, 2009
  • 4 Answers
SOURCE: my hayward heater gives a LO error when trying to
One of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. The limits are located in the black plastic header. Always make sure water is flowing through the heater at all times while checking the limits.
Posted on Mar 01, 2010
thepool
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
How do I winterize my Hayward pool heater
either blow water out with a blower then follow with a little antifreeze to make sure all water is out then remove freeze plugs on sides of heat exchange then remove pressure switch turn off gas valve and put a board or something on the top to keep out snow and weather
Sep 24, 2014 | Hayward H Series Pool & Spa Heater 400k...
How can I verify that water flow rate to my Hayward H series heater is above minimum required 20 GPM?
Most pool pump/filter systems are designed to achieve the minimum recommended flow rate. A pump system with at least 1HP motor should achieve the minimum flow rate, but a 0.75HP motor would likely also achieve it. The Hayward H series heaters do not include a water flow rate sensor, but rather use a water pressure sensor to verify the pump is operating. If the system has insufficient water flow even when the pressure is within normal operating limits, the heater will likely over heat and open the water pressure relief valve located on the outlet header. This condition could occur if the down-stream line is blocked (by a closed valve or similar condition). It is important to avoid this condition since the heater will release pressure via opening a relief valve, spilling water directly out of the heater manifold.
The only adjustment for hydraulic sensing within the H series heaters is the water pressure sensor. See other articles within fixya for this procedure.
Jun 21, 2014 | Hayward H Series Pool & Spa Heater 400k...
Hayward MILIVOLT H300 BANGING AND POPPING. STILL HEATS BANGING AND POPPING QUITS WHEN HEATING STOPS.
There are two things that can cause this...
low water flow
mineral build up in heat exchanger
Check and verify water flow through the heater
if that is ok, then the heat exchanger needs to be cleaned
heatman101
Sep 25, 2011 | Hayward H-series Electronic Gas Pool...
I have A hayward heater H100IDEVERYTIME the heater kicks on it makes A clunking noise and the inlet hose shakes
Check your water flow and make sure your by-passes are set to send water threw the heater. That is to say shut off. The water in the heater is over heating and the clunking is the water turning to steam.
Jun 26, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward Model H250IDL is leaking water from drain valve.
Water leaking from the heater is not a good sign. This is an indication of a leaking heat exhanger. The heat exchanger will have to be replaced and the part is made of copper. It is very expensive, depending on the age, you may just want to replace the entire heater. Exchangers usually leak due to bad water chemistry.
May 09, 2010 | Hayward H Series Pool & Spa Heater 400k...
My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Apr 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H300 heater runs but will not heat water
Your internal by-pass could be stuck open or the disc could be worn to the point of letting water pass too fast. Or your thermal control valve could be stuck open. These are both found in your water header going into the heater. Hope this helps, good luck.
Jul 02, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
Hi I have an Hayward H Series pool heater and the pilot doesn't stay lit when I depress the control to turn it on. Any quick solution for that ?
Check the thermocouple that the pilot light heats up. If it is not working then the gas to the pilot will not stay on.
Jul 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward h250, wont heat
Sounds like it could be the flame sensor.
Apr 04, 2009 | Hayward H Series Electronic Ignition...
Hayward H-series Electronic Gas Pool Heater H400 Logo
77 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
