Question about Pinpoint Boating
Pinpoint 7220 manual - Pinpoint Boating
-what do I do My MFC-7220 is printing faint-56% drum life and toner low indicator not on
It sounds like the corona wire may be dirty. Its a wire that self-charges to attract toner to the paper. Read your manual and see if it mentions print quality problems. If you decide to check inside this device, please disconnect the power cord.
Feb 28, 2015 | Brother MFC-7220 All-In-One Laser Printer
I just purchased a Brother 7220. I ould like to know how to set it up so that faxes are received through the computer so i can decide which to print and which to delete
hi
use the USB cable to connect to the computer, go to the fax set up and it will b self explanatoryu as to how to set up fax you receive. it is strongly suggested you read the manual to understand the unitas a whole
Aug 10, 2011 | Brother MFC-7220 All-In-One Laser Printer
How can I print a history report on my Brother MFC-7220 Plain Paper Laser Fax?
The report you want is called "Fax Journal, and it's number is 4.
Press "Reports" button (in the upper-right corner of the panel), then either go down (using up/down arrow keys) to "Fax Journal", or press number 4 directly, then confirm with "Menu/Set" key.
By the way, click here to download a PDF manual for your unit.
Good luck, and please leave testimonial if helped :)
Jul 06, 2010 | Brother MFC-7220 Plain Paper Laser Fax
Brother MFC 7220 How do I use the scanner on the Brother MFC-7220 ?
Hi there
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/BrotherDCP-7020-MFC-7220-MFC-7225N-MFC-7420-MFC-7820N-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
Mar 25, 2010 | Brother MFC-7220 All-In-One Laser Printer
How to reset brother printer MFC-7220
You should not just reset yr MFC-7220. Give yr specific problem.
Nov 16, 2009 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
'Unable to print' is shown on start-up by my (Brother 7220)
Hi
Do you know if the power in Dubai was 240 volts or 110 volts ?
you should also down load a new print driver for your printer and discard the other one
hope this helps
Greg
Aug 20, 2009 | Brother MFC-7220 Plain Paper Laser Fax
Boating Logo
Top Pinpoint Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Pinpoint Boating Expert? Answer questions, earn points and help others
