Question about Dell Inspiron 1525 Notebook
My dell inspiron 1525 microphone does not record.
It has Microphone Array,Sigma Tel High defInition Audio CODEC.When I want to contact my Skype contacts, they do not listen to me. I've tried everything like audio settings, settings sound on my laptop.It shows that Microphone Array works properly but steel one day it works , the other it does not.Can You Please help me to solve my problem, my laptop is nearly new. I bought it 6 monts ago. Thank You
  • 1 more comment
  • UBERCOOL Mar 25, 2009
    MOI AUSSI, actually no..,. my laptop just can't detect the mic.. T^T
    AND IT IS BUILT IT
    BUILT IN... ****
  • Vincent  dela cruz
    Vincent dela cruz May 11, 2010
    is this a built in microphone or USB connected microphone?
    New Friend:
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
Posted on Aug 23, 2010
  • Andrew Carpenter
    Andrew Carpenter Aug 27, 2013
    Well, I'll be darned. Yes, when I have the screen half-way closed, the integrated mic works. Thanks for confirming I'm not crazy.
  • 3 Answers
I would try reinstalling the sound drivers, but remove the ones on the computer already. it should reset the drivers.
Posted on Apr 01, 2009
4 Suggested Answers
SOURCE:
rtrahan
  • 741 Answers
SOURCE: Microphone not working on Dell Laptop
If you can hear windows booting up then the sound card is ok..you can double check it in Device Manager. To ensure the device drivers are up to date. Just find the sound card in the list of devices in Device manager and click on the "+" to expand it. Then right click on the sound device and click on update drivers. You can also uninstall the drivers and reboot. Plug and Play will pick up the correct drivers..double-check the cables also...good luck. Let me now if you have any questions
Posted on Mar 22, 2009
SOURCE: Internal mic won't work on dell 1521
I am having a problem with the sound on mine as well. I've tried these steps but there are 2 x's in the first step. So, i don't know what to click on. Could someone please e-mail me back at brit-c@hotmail.com with an answer?
Posted on Jun 16, 2009
SOURCE: my dell inspiron 1525 laptop
Hello Sunil
You can download all th edrivers for 'Dell Inspiron' from here http://www.getpcmemory.com/drivers/download-dell-inspiron-1525-notebook-windows-xp-drivers/
Posted on Jun 23, 2011
Ecs 945GCT-M/1333 problema de audio
google translated
945GCT-M/1333 ecs audio problem
I'm trying to run a headset for Skype, so far had no problems with my speakers, now there is noise interference (?) Sometimes, and skype does not recognize the micro (and it works because I tried it on another compu ) .. not if some codec or something .. everything that relates to sound hardware refers to "Sigma tel audio" and not if the modem ... any information is welcome! garcias!
Click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam.
Click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver W7.
Click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark?
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
Open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call.
Make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment.
Click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings.
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
Select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
Hope this helps
Nov 14, 2012 | Asrock 775VM8 Motherboard
When i record a video using my youcam, there is no audio recorded. therefore there is only a video without audio. how can i solve this problem?
try to go to settings on the left side.. check the audio device.. it should be Integrated Microphone Array (IDT High Definition Audio CODEC).. i tried this and it works..
Apr 21, 2011 | CyberLink YouCam
Hi. We have a problem with microphone on Skype. Other side can't hear us althouh we have tried every solution recommended on Skype and microphone settings should be ok. Should we download some codec or...
It seems that microphone or volume issue on the other end. Can you try recording through mic and playing back? Hope it works, then there is no issue on your end.
Your sound settings have such sound recorder options....
Apr 16, 2011 | HP Pavilion dv6208nr Notebook
I have sigma tel high definition codec and my machine is buympc d945 my sound is not working properply plz resolve my this biggest issue
You can get the audio drivers here
Under the heading Sound Download click on either the Windows XP or Vista download depending on your operating system.
Feb 12, 2011 | MPC Computers Computers & Internet
Inspiron 640m says idt high definition audio codec can't work (code 10) i tried uninstalling and using the hardware wizard to reinstall. i think i removed part of the program for sigma tel audio by...
If you go to Microsofts web site and choose updates, you may well find it isn't needed at all. Did your sound stop working? If it did got to Dell.com and update the drivers from there.
Feb 10, 2011 | Dell Inspiron 640m PC Notebook
Inter Audio Sudio Controller states Sonic Focus
Try reinstalling your audio drivers, or use system restore to undo the update if yo are sure of that.
Reinstalling the proper drivers should generally fix it though.
In case you don't have them anymore, try the manufacturer's website or a driver finder program.
Dec 14, 2009 | Intel ESS ES1868F Sound Card
I recently have had issues regarding my Dell Inspiron 1525 built in microphone. I run on Vista and have done some troubleshooting of my own. I have check all volumes and they are all up to 100%. The audio...
double clock at speaker at the left of toolbar then in options goto the properties go to recording option and confirm there that microphone is checked and then click ok
and then over there check the check box of microphone and increase the volume of microphone. hopefully it will work fine
Sep 03, 2009 | Computers & Internet
IDT high definition audio codec (code 10)
Try and install the "Modem" first restart and then wait if it ask for a driver in your audio.
Mar 27, 2009 | Dell Computers & Internet
I need the Sigma Tel Audio Driver to use my webcam
you need to set cam up with skype follow instructions
Go to TOOLS, then OPTIONS, and click on
Audio Settings
and set the Microphone and Speakers
to the computer Audio Card.
Then click on the Video Settings.
The camera if installed properly
will come up and show a picture.
Then on the bottom of the page click on Save.
please let me know if this has helped or we will need to try another solution
did your cam come with software
Jan 27, 2009 | Microsoft LifeCam VX-6000 Webcam
Dell Inspiron 1525 Notebook Logo
1,752 people viewed this question
Clive
Clive
Alun Cox
