Question about Ainol 10" Novo 10 Hero 16GB Dual Core IPS 1.5Ghz Android 4.1 Jelly Bean Tablet PC Dual Camera HDMI Bluetooth WIFI
Will not turn on
Bought a novo 10 hero tablet that didn't come with a charger. first charger I bought had a 5v-2a output. the charger wouldn't charge at all and nothing happened, I assumed the tablet was broken but then I read that I needed a 12v charger. I then went and bought a 12v 0.5a ac adapter the tablet started up and charged fine for approx. 3 hours after updates were installed a red exclamation mark appeared in the battery symbol it said 47% before this popped up. apparently the tablet burned out the charger I then bought another charger 12v 500ma this time the unit never came on or actually functioned. the new charger would work in other devices fine I tried it just to test it. after 40 mins of trying to charge the tablet the charger now doesn't work with any devices at all. the tablet keeps blowing charges and wont charge at all. please help
    Top Expert:
  • Ainol Master
  • 12,620 Answers
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Posted on Mar 13, 2017
2 Suggested Answers
  • 11 Answers
SOURCE: Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
Posted on Dec 06, 2013
My hipstreet pulse 5v charger broke & i have bought several 5v needle chargers that plug into my tablet but wont register or connect to charge it why?
Hi yes the problem using different chargers polarity can be positive & negative. On the male plug or it can be negative & posative ....also they can be AC CURRENT OR DC CURRENT U NEED A MULTIMETER TO TEST THEM ...OR ITCOULD BE a fault with the tablet or the Charging socket .,cheers
Jun 22, 2016 | Tablets & eReaders
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
What charger to buy as original charger lost?
Go to a shop that sells the tablet and ask to see one, take note of the charger and your good to go. Otherwise go online to Amazon etc. They are 5v 2A and come as USB or wall charge. They are everywhere online for a few bucks.
Aug 15, 2014 | Nabi 2 Disney Edition Tablet
Dec 06, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
Ainol Novo 10 Hero Tablet won't turn on/off on power button... it only works from reset button... also auto rotate doesnt work... Also whole tablet gets stuck always after 10min useage... ideas???
I have same problem as you have: the on /off switch completely not work . It cannot start only way use the reset pin then cannot off.Mine also has freezing problem.I went to setting then go to factory reset erase all my data. The freezing gone but the on / off switch still not work then I think this could hardware problem. Only way is open it up.Since this is a traumata act I have to use as the last act.Meanwhile I set the display screen close in 2 minutes when want to stop it.Any one here have any better idea please help.
Apr 09, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
My ainol novo hero is frozen on home screen
The simple way to tempary solve this problem by just use a pin to insert to the small hole next to the power supply hole.this will turn off the set and start from begining(not reset to factory setting).If your problem back again then need to consider to go to backup and reset to reset to factory setting.It will lose all your data.If still not work contact the factory and install update firmware./
Jan 22, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
try pushing in the mic button with a safety pin. That used to work on mine, now mine wont turn on at all. : (
Dec 26, 2012 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
How do u charge an irulu tablet, didnt get a charger with it
I got my tablet with a charger but after some time it got damaged.. NOW I USE THE MINI-USB cable to charge it.. you can use an adaptor like the one that comes with the Samsung galaxy cellphone and use the mini usb cable with it.. Hope you understand my mess.. good look..
Dec 13, 2012 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Ainol 10" Novo 10 Hero 16GB Dual Core IPS 1.5Ghz Android 4.1 Jelly Bean Tablet PC Dual Camera HDMI Bluetooth WIFI Logo
183 people viewed this question
Top Ainol Tablets & eReaders Experts
Are you an Ainol Tablet and eReader Expert? Answer questions, earn points and help others
