Question about Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio
Need more receive - Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio
    Novelist:
  • Connex Expert
  • 500 Answers
Use a longer antenna or get it higher..
102" whip for mobiles.
maco v 5/8, army big stik, or Bandit for base. or a long beam 5 or 6 element type.
for example..
Posted on Nov 18, 2015
How much do they cost. I am going buy one.
Amanda, Audio & Video Receivers prices can range from a couple hundred dollars to thousands. Decide on your needs and then search the stores/ net. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Receivers Audio Home Theatre Receivers Best Buy Canada
Home Theatre Receivers Receivers and Amplifiers at 2001 Audio Video
Amazon com Receivers Amplifiers Electronics Amplifiers Receivers...
How to buy receiver The ultimate buying guide
Aug 26, 2016 | Audio Players & Recorders
How to hook up a denon avr -1706 receiver To a lg smart tv
If you are tuning in TV stations with the TV set, you will need either an optical or a coaxial audio cable to go from the digital audio out of the TV to a digital audio in on the receiver. This setup should give you 5.1 Dolby digital sound. You can also use a pair of red and white rca cables, but you will only have 2 channel sound. You may need to set the TV to output the audio to external speakers. You will need to set the receiver to the input the TV audio is connected to.
If you want to watch Sat or Cable, you probably need a couple of HDMI cables. One HDMI cable will go from the output of the Sat/Cable box to the appropriate HDMI input on the receiver. The second HDMI cable will go from the Monitor Out on the receiver to an HDMI Input on the TV. You may need to set the receiver to output HDMI audio from the receiver, and not the TV. You will need to set the TV to the HDMI Input you connected to on the TV. You will also need to set the receiver to the input the Sat/Cable box is connected to.
Details of both of these setups should be covered in the receiver and the TV manuals. Refer to them for the detailed connections and settings you need to make.
Good Luck!
Mar 02, 2015 | Denon Audio Players & Recorders
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
I need to purchase a Hunter ceiling fan receiver. The receiver model # is 85069-060.
hunter technical support number is-- 1-888-830-1326 call this number and they should be able to help. good-day ! just tell them you need a new receiver, and give them the model number of the receiver and the fan model number.
Aug 25, 2011 | Hunter Ceiling Fan Remote Receiver...
I just bought a Panasonic plasma tv model TCP50S2 and I can't seem to get my Kenwood receiver to work with it. Do I need to set the remote to the Panasonic tc? If so does anyon know the code number? I...
I assume you want the TV sound through the receiver?
You need to connect the TV digital out to the receivers digtal in.
This is probably an optical connection.
Then you need to switch the receiver to the correct input. You may also need to tell the receiver what kind of connection is made: Optical or coaxial, if it doesn't detect this automaticly.
Sep 22, 2010 | Kenwood VR-705 Receiver
I need a fan for my stereo receiver model number sa-g76
Goto radio shack and ask for a 120 volt boxer fan. Just set it on top of receiver and use the switched power outlet on back of receiver if equiped. Good luck
May 20, 2010 | Audio Players & Recorders
I have a Yamaha HTR-5440 receiver and I want to connect it to my Directtv Plus HD DVR satilite receiver what do I need
If your yamaha receiver has Hdmi upconversion and HDMI pass through you should only need an HDMI cable. One from the directv receiver to the Yamaha Receiver and another from the yamaha receiver to the tv. If it does not have HDMI then you'll need component video cables and 1 optical cable.
Oct 23, 2009 | Audio Players & Recorders
Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Mar 15, 2009 | Yamaha HTR-6130 Receiver
Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio Logo
143 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
