Question about Vehicle Parts & Accessories
Cant drive my car
Replacing a broken very needed part for my gas pedal
  • mkingoc May 08, 2013
    Thanks man. A friend took me to a junk yard, it was pretty easy to replace after that.
  • 38 Answers
Only thing you can do there is have someone else take you to get the part if you can replace it yourself, or if not tow it to a dealer somehow, that is not something you can just put duck tape and screws in.
Posted on May 08, 2013
Driving on hwy 2002 pathfinder lost gas pedal pulled into neutral it revs up put back in drive no gas pedal what do I do
Mate look under your bonnet I'm betting you'll find a broken accelerator cable spring....
Mar 19, 2016 | Cars & Trucks
2002 ford taurus gas pedal goes to the floor and getting no acceleration. the pedal itself is loose and won't retract into the up position.
The spring or wire that connects your pedal to the throttle body may broken or damaged. Check under your hood and look at the throttle body (it's the carburetor looking thing). There should be a steel wire connected to it coming from the back of the engine bay. It should connect on the side where you'll see a few springs. If nothing looks broken there, turn the part of the throttle body connected to the spring and wire. If it revs up when you move it, then the cable could be broken somewhere between there and the gas pedal.
Alternatively, the linkage on the pedal could have been disconnected some how. Check behind and above the gas pedal to see if eveything is connected properly.
Apr 24, 2014 | 2002 Ford Taurus
Does anyone know how much it costs to replace the computer in my 2004 Trailblazer
Don't start replacing parts until you know for sure what has failed. I would say that the PCM is not the problem here. As far as the gas pedal is concerned, it sounds like you may have a broken linkage at the pedal, these trucks do not have a cable but only a rheostat that the computer reads.
The tachometer and speedometer problem could be a bad cluster.
You need to see a good mechanic to get a diagnosis.
Sep 01, 2012 | 2004 Chevrolet TrailBlazer
I have 1999Chevy suburban with 6.5 turbo diesel motor.it idles up and down and when driving the gas pedal is real touchy Wat is the problem and were do i locate the problem
Check the help links related to this problem.Click the link below to go through its troubleshooting procedure :-----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html---------
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
-------Complete loss of brake pedal then all gets normal? http://repairhelpcenter.blogspot.com/2012/01/complete-loss-of-brake-pedal-then-all.html
------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
--------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down?
http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
After replacing brake rotors and pads, brake pedal remains on floor? http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
accelerator pedal sensor? http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
For rough idle issues and problem troubleshooting,go through the help links provided below :----- van idles rough?
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
This will help.
Thanks.
Mar 01, 2012 | 1999 GMC Suburban
Bought a used 1996 couger and the heater core is by passed. im asumming the heat core needs replacing is it necessary to remove the entire dash my haynes manual does not say to remove it but when i follow...
1996 mercury cougar heater core replacement
we just bought a car with the same problem
http://members.tccoa.com/timb/Heatercore.htm
we did not have the bolt above the gas pedal
"1 on the tunnel above the gas pedal"
Jan 22, 2011 | 1996 Mercury Cougar XR7
When pushing on the gas pedal from a stop gas pedal gets stuck for a moment
take your car to a qualified machanic ASAP like now you may have a strands broken on the meteal stranded accelarator cable or something bent under the dash above the pedal this can be serious it may get stuck if it does turn the key to the ignition a half click back so the car engines electrical power is taken away but the sterring wheel remains unlocked use e-brake for stopping if stick shift depress clutch first then follow rest of instructions
Jan 03, 2011 | 1993 Toyota Corolla
Lost pressure in gas peddle
Hmmm well to start the pressure in you gas pedal comes from your throttle body, not your spark plugs. Secondly, there is only one cable going to your gas pedal, the other one is your cruise control cable.
Repair your throttle cable, or the spring on your throttle body is broken. it should be a fairly easy thing to fix.
Jul 22, 2008 | 1994 Ford Mustang
Vehicle Parts & Accessories Logo
106 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
