Question about Garden
Wheelhorse 314 engines dies when pto is engaged
Seat switch is jumped, enigine will not start with key has to be jumped at solenoid but starts great. pto is engaged and engine dies. found 2 wires corroded and spliced together now the dash warning lights all light up but oil light keeps blinking. Why does the pto kill the engine? Thanks for the help
    Scholar:
  • 90 Answers
I am assuming you have a manual PTO clutch since you did not mention a PTO switch. The starting circuit generally is a series of switches wired in line (series) with each other. You have bypassed the seat but there is usually a switch for neutral, PTO, oil level, and clutch. You will need to trace the wires from one to the other to find the problem. If the seat has a double switch (3 or 4 wires) it is wired through the PTO switch which may be a double switch to short out the ignition so that part of the circuit should stay open to operate. If the oil level is ok and the oil has been changed as recommended you may better consult a Wheelhorse service person. Bypassing the switches is for testing only! I DO NOT RECOMEND LEAVING ANY SAFETY SWITCH BYPASSED. Any defective or out of adjustment switch should be replaced or corrected.
Posted on Feb 04, 2015
SOURCE: Ignition does not crank engine
If it is cranking over it should start. If you are just jumping the solenoid then you have a switch problem.If it is just plain not starting then you need a complete tuneup. It a process of elimination, you need air, gas, and a spark. Then it will run.donnyb60
Posted on Mar 23, 2009
panilling9
  • 284 Answers
SOURCE: craftsman model 917.272950 lawn tractor won't start
OPERATOR PRESENCE SYSTEM
Be sure operator presence and interlock
systems are working properly, If your
tractor does not function as described,
repair the problem immediately.
• The engine should not start unless the
clutch/brake pedal is fully depressed
and attachement clutch control is in the
disengaged position.
• When the engine is running, any
attempt by the operator to leave the
seat without first setting the parking
brake should shut off the engine.
• When the engine is running and the
attachment clutch is engaged, any
seat should shut off the engine.
• The attachment clutch should never
operate unless the operator is in the
seat.
Check your seat switch and clutch switch wires be sure that the connection to each switch is making contact and the mechanism that activates the switch is actually activateing them in other words be sure the clutch is pushing the switch in and your seat switch is occupied and be sure all grounding wires a intack
especially from your battery negative to the frame.You also could have a neutral safety switch which requires your transmission to be in neural.
try these things and let us know how we can further help from more of your input.
Posted on Jun 08, 2009
  • 202 Answers
SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
Posted on Jul 19, 2009
  • 153 Answers
SOURCE: When I engage the front PTO the engine dies.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
Posted on Oct 14, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
Engine will not start. Jumped out solenoid and engine starts but kills when PTO switch is engaged to operate blades. Any ideas?
yes but whats a 12 volt light bulb do that connected across the start solinod when the key is turned to start ?
id bet it don't lite! this is proof theres a high resistance fault in one of your safety switches (very common)
Sep 15, 2015 | Garden
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
Toro Lawn Tractor Won't Start - Wheel Horse 13-38 XL 71185
well if it turns over with solinoind jumped out and not with the key id say yes your on the right track as it's something in the safe to start circuit could those wires you found posibly be near the seat maybe if so I'll bet they fit in a seat switch that may have got unhooked for something
Nov 12, 2013 | Toro Garden
Tora Lawn Tractor Won't Start . Wheel Horse 13-38 XL
It is not uncommon for a safety switch to get misaligned and not work correctly, also it is not uncommon for a switch not to work even if it is engaged.
You need to check all the switches that must all be properly aligned and engaged in order for the engine to start. As for the light blue wire, I am not sure 100% however typically blue wireds on wheel horse equipment are used in the ignition system. Depending on your model it may be the main ignition power line which runs from the ignition switch (S) connection or (start) connection, then goes to PTO interlock switch, then goes to the Pedal interlock switch, then finally to the starter solenoid. Which sounds like where you have to look because along this blue wire at many points and switches, there is a problem either with a connection (the lose blue wire) or a bad interlock switch along it's way to the starter solenoid. You should also check the PTO interlock switch because it also is connected to a kill relay that will prevent the engine from starting id it is faulty (that light click your hearing, the starter solenoid would be a louder click).
There is a typical ignition service manual available at http://www.mywheelhorse.com/graphics/file/Engines/Engine-Electrical_Service-Manual.pdf It has the typical wireing diagram and all the information you will need presuming you have enough electrical background to use a multimeter.
The website at http://www.scribd.com/doc/47347708/Toro-wheelhorse-Demystification-Electical-wiring-diagrams-for-all-WheelHorse-tractors has diagrams specific for each model but you have to make an account (free) to use the website, and lastly the website http://www.mywheelhorse.com is a invaluable website for anyone who owns a Wheel Horse. Let me know what you figure out!
John deere 2210 engine dies when engaging pto, seat switch good
are you sitting in the seat or have you jumped the safety switch under the seat before you engage the PTO I believe our tractors use an electric solenoid to apply hydraulic pressure to a wet clutch inside the trans axle I would think it would be OK with your chipper I have a 450 tiller that was built for the older 400 models 425 445 455 that I now use with my 2210 If I hit a large root or stone when using it with my old 445 it would stall the tractor at full power. Now with the 2210 it will actually slip the clutch on the tiller s PTO shaft I think the correct approach would be to increase your RPM s gradually or start increasing the power just as you trip the PTO switch. You want enough RPM s to create enough hydraulic pressure to run the PTO circuit so that you don t slip the wet clutch anymore than necessary and you want the RPM s low enough so that you don t shock the mechanical systems too severely at start up
Let me know how it works
Feb 02, 2012 | Garden
My dad is trying to fix a lawn mower for a friend. It is a John Deere LX172. Whenever the mower deck is engaged or the unit is put into gear, the engine dies as if the ignition were shut off. I think...
Check the seat switch. That will cause your problem. It happened to me when I was not sitting on seat and turned deck on. Mine is a LX172 also.
Aug 12, 2011 | Garden
Ingnition will not even click. Replaced iginition switch, solenoid and spark plug. Checked seat switch, transmission switch, fuse. Started motor turns when jumped. Battery fully charged. Fresh gas. ...
Hi, is the deck engagement lever off or the pto switched off? If it uses a lever check the switch on the lever. If it uses a pto check the pto switch. Hope this helps, regards Phil.
Jun 24, 2011 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Hi have a Toro wheelhorse 212-6. new to us. wont cut.
Yes, there is a switch on the dash. It operates an electric PTO or clutch for the mower blades. That is how most lawn tractors work. Of course , yours could be different, but if it is, It still has a clutch somewhere and a lever to engage the blades. Most of the electric ones are controlled by safety switches, One being in the seat, if you are not in the seat, it will not connect, if you get out of the seat with it running, the engine will cut off. Sometimes one is on the mowing deck, it will not connect if the deck is up. If you cannot get the PTO to work, it could be shot. (Rare) You can hear it go when it starts, check it out, hope this helps.
Jun 06, 2010 | Garden
Craftsman model 917.272950 lawn tractor won't start
seat.
Jun 08, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
281 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
