SOURCE: need wireing diagram for a rci 2980 to tug8 mic
Here is what I have: If the Tug 8 is a 4 wire cable,1/shield 2/white 3/red 4/black 5/N/C 6/N/C
If the TUG 8 is 6 wire cable,1/shield & blue 2/white 3/red 4/black 5/N/C 6/N/C .The reason I gave two diagrams is I can never remember if the 8 or the 9 is 4 wire cable.Also if your radio keys up when you plug mic in reverse the black and red.Good Luck and take care!
SOURCE: The s-meter goes down scale when I am modulating.
the reason i saked is that if you turn the power all the way up it tends to reverse modulate. this happens because the power is using all the transmit voltage for the final and the modulation circuit is trying to use as much as it can so the radio is most likly out of alignment and needs to be realigned. its not that hard if you have the service manual and the correct equipment. i have a factory authorized shop and we do alot of realignments due to the cb shops tweaking the 10 meter radios.
SOURCE: scematic
a 100 ohm 1 watt resistor soldered across the pa and external speaker jacks work good for talkback
SOURCE: rci 2980 no modauliton on am/lsb/usb/fm.but good
is it steady output on AM with no modulation swing. then change the Audio transistor. SSB should work. they feed straight through to rf final. if no modulation on either mode, then check the mic, audio ic preamp.
