Vizio blu ray player
When I turn the tv (also a Vizio) to HDMI 1. With the blu ray player on there is no picture or sound. I'm also using a Vizio HDMI cable. Can it be fixed?
    Genius:
  • 1,054 Answers
Have you tried a different hdmi jack, or a different cable?
Posted on May 24, 2013
  • 6 Answers
SOURCE: My HDMI cable wont work from my new Blu-Ray player
On the blu- ray player you have to set it to HDMI in the options or else it wont work
Posted on Oct 24, 2009
  • 53 Answers
SOURCE: How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Posted on Dec 29, 2009
  • 1705 Answers
SOURCE: I put a regular dvd into my blu ray player but it
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
Posted on Mar 31, 2010
SOURCE: Just purchased a new samsung blu ray player with
onkyo receivers have a problem, see
http://www.hdtvsupply.com/hdmi-cable-booster.html
Posted on Jul 06, 2010
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
My Vizio blu Ray player displays a pink screen. What to do? I am using an Hdmi cable and Time Warner HD box.
You hook up your Blue Ray player to your TV using the HDMI cable, not to your cable box.
Jan 12, 2015 | Vizio Televison & Video
My blu ray 3d dvd player will not show picture on blu ray discs only sound but will play regular dvds correctly
The video for blu ray disks come out of the HDMI port and that has to be connected to the TV for video. If it is connected, make sure the TV is switched to the correct HDMI port on the TV (assuming you have a flat screen HDTV).
May 11, 2014 | Vizio Televison & Video
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
The picture will not show on tv but he audio comes through - what's wrong? We have checked all cables. We are not using the HDMI.
What are you using?
Is it hooked through another device?
Things to check
Is the source on the tv in the right place? Video, Input 1, Input 2 ect.
Is the TV on the right channel.
Some of these have a channel selection on the back, it will be a switch with the number 3 and 4 on it.
Make sure the TV is on the same number.
if you are picking up audio than this is more than likely your problem.
Jul 02, 2011 | Vizio VBR210 Blu-Ray Player
I get picture but no sound on my samsung blu ray
  1. Are you connecting through HDMI?
  2. Do you have another source to test the HDMI cable to make sure it is not faulty?
  3. Do you have a second HDMI Cable you could test and connect with?
  4. Does your TV have another HDMI Connection you can use to connect with instead?
Essentially we are looking to determine whether or not it is the TV's HDMI connector, the Blu-Ray's, or just the HDMI cable in general.
May 12, 2011 | Samsung BD-P1500 Blu-Ray Player
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
Electro Med Services...
