Question about Garden
M t d yardman 638 r l rid mower
How to replace drive belt
  • 138 Answers
SOURCE: broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Posted on Aug 15, 2009
mowerman1857
  • 389 Answers
SOURCE: the drive belt on my 42 inch yardman tractor is
Once a belt has slipped to the point of "smoking" it is time to replace it. It will have a worn spot on it that will cause a vibration throughout your entire tractor when you are driving in addition to being weak at the burned point
Posted on Sep 16, 2009
  • 8404 Answers
SOURCE: Cahnging drive belt on mower
dont understand your question ... get the belt ... it was designed to fit ... there are probably at least three pulleys. put the belt around the motor pulley and the trans pulley then figure out how the clutch or tensioner pulley interact with it.
Posted on May 01, 2010
  • 16 Answers
SOURCE: how do you tighten lower belt on a 42 ich yardman
By lower belt i suppose you are reffering to the drive belt or the blade deck belt, either way these belts are usually tensioned by a spring loaded idler pulley. If the belt is still too loose even with the pulley tensioning it, it may be time for a new belt (that one may have streched out a bit).
Posted on May 07, 2010
  • 150 Answers
SOURCE: need a diagram to show
that diagram should be on the mower deck. Clean it off you should see it.
Posted on Sep 28, 2010
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
How to change a Yardman M.T.d. transmission drive belt diagram on 46" cut?
You can go to the Yardman website and download the service/owner's manual.
Aug 18, 2014 | Garden
Mtd yardman differential
check your drive belts, pulley's and belt tensioner... you could of gotten better help if you would of included the model #
Dec 03, 2013 | Mtd Garden
Mower for Yardman 760 will only move in forward gear or reverse for a few minutes, then will not move in either direction whether the blades are engaged or not.
The drive belt going to the rear transaxle is either worn or the incorrect length. If drive belt has not been replaced in awhile, I would recommend getting it replaced. Hope this helps.
Sep 26, 2013 | Mtd Garden
Yardman 42" . I just replaced the belt and now the
my moor goes a lot slower than useal pleas help me it is mtd 32.ins about 9 years old
Mar 12, 2011 | Mtd Drive Belt 42"
Drive belt diagram for mtd yardman 42"
i need a diagram showing for a 20hp yardman tractor model number 13AT605G755
Dec 07, 2010 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
How do I repair my Yardman riding mower power steering?
the yardman ive got the drive belt broke got the new 1 on it but now it just stays in 1 gear evan if i put it on 7
Jul 15, 2010 | Mtd Garden
The drive belt on my 42 inch yardman tractor is
Sep 16, 2009 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
