Question about JVC JLC37BC3002
Program tv says no signal
Saying no signal when input is set to TV
    Problem Solver:
  • 18 Answers
The tv is in digital mode it need to be in anolog
Posted on Sep 19, 2013
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
My TCL TV has a blue screen saying no signal. What button do I push on my new universal remote to get my cable tv
the button will be labeled either source, input, tv/video. if the direct TV remote was programmed for your television there is a tv/input button
Nov 03, 2013 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
TV saying no signal
The TV will flash this "No Signal" when it does not see a live signal at the selected input of your TV.
It sounds like the signal at the TV's input is not good to the TV, or the main board in the TV is having a problem and processing the signals correctly.
Try selecting a different woring device connected to the TV's input like HDMI1, Component1, or ..... to see if other inputs are working on the TV.
Good Luck.
Jun 27, 2010 | LG 42LH200C LCD TV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Not being able to change inputs
Change the input setting on the tv not the remote.
If you are using a universal remote it may not be programmed correctly.
When you push the input button on the remote it is changing it to the Over The Air Antenna, it is not recieving a signal and there is no channel label added for the station it is set to.
If you do have an antenna connected, from the menu do a channel search and see if it can find any signal.
Let me know how it goes, I can assist further.
lone99star
Jan 09, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Not programmed
It is not picking up signal. Look on your remote for a button marked tv/video or inputs. Try to switch back to rite input or your sat or cable box has failed. Try another tv to see if you get pix
Craig www.classtorations.com
Jun 07, 2008 | LG Televison & Video
JVC JLC37BC3002 Logo
336 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
