Question about Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor
Mower won't turn over
I title mower on its side today for about 1 minute and now it won't turn over. what could cause this? and how can i resolve it?
  • Craftsman Master
  • 2,411 Answers
I would suggest by tipping you have let oil come into the combustion chambers so I would suggest take the spark plugs out and let the engine turn over for 10 to 15 seconds to blow the access oil out
Replace the plug better a new one and you may have to run the starter to get it to fire as there will still be a residue of oil in there yet.
One should never tip a gasoline engine as this will cause problems in the end.
Posted on Mar 26, 2015
  • Craftsman Master
  • 2,478 Answers
The valves are out of ajustment .
Posted on Jun 25, 2013
  • Dan Apthorp Mar 26, 2015
    I would suggest by tipping you have let oil come into the combustion chambers so I would suggest take the spark plugs out and let the engine turn over for 10 to 15 seconds to blow the access oil out Replace the plug better a new one and you may have to run the starter to get it to fire as there will still be a residue of oil in there yet.
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Huskee LT 4200 Lawn Tractor I had to jump my mower today and mowed for 45 minutes, turned it off, added gas, started mowing again for 30 minutes, turned it off and now it won't start, turn over or...
A couple of possibilities, either the main fuse has blown, they are normally an auto motive design and located undrt the the hood of the machine, or the start solinoid has burnt out.
Jun 18, 2013 | Garden
2006 huskee supreme slt 4600 fuse keeps blowing, any ideas, it's the one by the gas tank
you have a wire grounding causing the fuse to blow you will have to trace wires to see if one is pinched or rubbed raw
Jun 17, 2013 | Garden
Snowblower won't start this year. Machine
Did you run the engine for about 15 minutes after you added the fuel conditioner? If not then the conditioner didn't get into the carburetor and you probably will need to take it apart and clean it again. The ethanol in today's fuel causes problems in carbs that sit
Jan 20, 2013 | Garden
Mower won't start after short use
have you change your air filter for the season check anything to do with your carb area to much dust in air can get in to carb causing to engine to work harder
Jun 05, 2012 | Briggs & Stratton Garden
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
I have a craftsman 5.5hp 3 in 1 Eager 1. Im having a problem starting it I've changed the spark plug and it still wont start any suggestions
Your carburetor probably needs a good cleaning. If it has the Tecumseh engine with the sideways carb on it, there is one thing to check quickly. Remove that brass bolt (main jet) on the bottom of the float bowl with a 1/2 inch wrench. Check all the tiny holes in it and make sure they're not clogged. You'll find one very very very tiny (I can barely even see it with my old eyes) hole right at the very top of the threads on that bolt and it gets clogged very easily with today's ethanol gasoline. If that gets clogged, your mower won't start. Also make note of the way the bowl is installed. It MUST be put on with the bevel side toward the hinge on your float or the float won't operate. Best of luck. I hope this helps.
James
Aug 25, 2011 | Craftsman Garden
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor Logo
254 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
