Question about Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D
Aces aspire desktop am1100
I have trouble when i start up it shown no signal on monitor ......i try many things such as removing memory sticks unplug and replug harddrive video card ,fans ,accesories and after a while for nothing special after doing a lot of restart and restart over it open with a configuration screen saying f1 to continue and esc to enter set up........then after i ve done my things and turn it down , i have to restart over all these operation ,anybody have a clue on this .thank you
  • Acer Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Posted on May 05, 2013
  • 51 Answers
SOURCE: A display problem in my Acer desktop pc
techguru 2009: First thing disconnect all power. Remove all drives (hard drive, CD/DVD, Floppy). Then remove all PCI cards. Also slowly remove the Memory cards. You should only have the motherboard w/processor and the power supply connected, do not connect the monitor or mouse\keyboard. If you have a CMOS battery also remove it. Careful turn the power on, you should hear several beeps. That is letting you know that there is no memory installed. Turn power off disconnect power cord. Slowly install the memory cards, keyboard, mouse, monitor. If you have a pci video card install it now. Turn power on. you should see the bios loading then error message there is no disk or operating syste. turn power off and start connecting one device at a time so your bios can recognize it. This should let you know if you have faulty hardwareby isolating each install. If you still have problems let me know.
Posted on Feb 24, 2009
leecom72
  • 4806 Answers
SOURCE: Get NO SIGNAL on Acer M1640~Monitor is Fine~Is CPU
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
Good luck
Posted on Jun 28, 2009
Geekman
  • 32281 Answers
SOURCE: ACER Aspire L100 Desktop is dead?
If the hard drive is OK then you can remove the hard drive from the desktop case, and insert the hard drive into a USB 3 1/2" hard drive adapter case, this should come with a power adapter. These are available at your friendly computer shop.
Boot up the laptop then plug this USB hard drive adapter into the laptop's USB port. The laptop will see this as an external USB hard drive. You can open the various folders and files on this external drive and copy the folders and files to the laptop.
You can delete the Windows folder and Program Folders on this external drive to free up disk space and use this as a back up drive etc.
If you are not sure how to remove the hard drive and install it into an USB hard disk case, then I suggest you get a computer savy friend to help you.
Posted on Dec 08, 2009
  • 1015 Answers
SOURCE: Acer AM5641-U5520A will not
If you removed the memory modules and there is no change then I would start disconnecting one device at a time to see if that is causing the problem. Start by disconnecting the cd/dvd rom and then try booting the computer. Then try disconnecting any floppy drives or pci cards(except for video card). If it has a pci/agp video card then you will need to remove it and test it in another computer or test a working one in the problem computer. If it has built-in video then you will need to test a working video card in the problem computer. It could also be an issue with the power supply so remove it and test it in another computer or swap it out with a known working power supply. Also check the mother board screws that hold the board to the chassi are tight(the board uses them as a ground). Blow any dust out of the case and verify that there are no loose connectors. Also verify that the monitor is not the problem by testing it with another computer. Usually when a CPU is defective the computer will not respond to anything and will act "dead" so it does not sound like the CPU. If everything else checks out then it could be a bad motherboard.
Posted on Dec 28, 2009
  • 35 Answers
SOURCE: I am working a computer an Acer Aspire M5640
Nothing showing up on the screen, definitely not a monitor issue the way you describe it. And you did all physical repair checks and such? Then the most likely problem I see is with the operating system. Windows Vista is so glitchy that any number of things could go wrong with it. I wouldn't put it past that OS. If you could get past the monitor issue perhaps you can uninstall that OS and upgrade to windows seven. Otherwise I'd take it in for a more professional diagnosis =/
Posted on Mar 23, 2010
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Aces Aspire M1640 desktop-pc starts but the monitor says NO SIGNAL. Tried various monitors and videocards without result. Can't find what mainbord is in it to have it changed. Regards, Toine
black out can be caused by series of things. Power supply is one. Second is the motherboard, memory and the processor aside from the video card. Motherboard and processor can be isolated,first is to remove the rest of the devices such as hard disk and cards and memory. Beep sound means your board is still doing fine. Re install all the devices and power on again. Good luck
Sep 12, 2010 | Acer Aspire M1640 Refurbished Intel...
Motherboard acer A1100-B1300A.... ????
Knowing the model of the mobo will not do anything if you know it takes
DDR2 5300.
And you can find tons of 1GB,2GB,4GB sticks.
If you want to know what memory MFG are compatible with you system
go to the Acer website.
As you can see at the website I posted below there are a lot of memory you can get.
Here are 12 different brands of 5300 2GB sticks of memory.
If your sure the motherboard takes 5300.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010170147%201052408745%201052307859&name=2GB
Feb 08, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
Screen starts then shuts down....greenlight comes on then switches to orange light...i have tried so many things ie unplugging all cords, removing dust....
It sounds to me like you may have a memory issue. I have taken the liberty of looking up the compatible memory for your system.
Each memory slot can hold DDR2 PC2-6400,DDR2 PC2-5300 with a maximum of 2GB per slot.*
*Not to exceed manufacturer supported memory.
Price from $55/stick
Good Luck!
JL
Dec 30, 2009 | Acer Aspire m5640 PC Desktop
Hard drive light flashes 10 time, but screen does not power on
man jst remove ur ram nd use a eraser rub the ram then insert the ram properly nd also check ur cmos battery.......ur work is done....
Aug 30, 2009 | E-Machines eMachines Desktop PC
When i unplugged the computer and moved it within the same room and tried to hook it back up it started to come on then there was a beeping noise that would not go away and the monitor says no signal and...
The beeping sound means that a pci card or a stick of ram has come loose. What you need to di is open up the side of your pc tower and firmly press down on the pci cards and ram to make sure there secured and then put side back on pc and start pc back up to see if noise has gone. Hope this helps and thanks for using Fixya.
Jul 17, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Good luck
Jun 28, 2009 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire M1100 no signal to monitor when starts
Got the same model. Had the same problem.
Play with the memory sticks.
Remove all but one.
Swap out memory for different memory.
Worked for me.
Jan 31, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
I started my HP computer today and it starting beeping, the tower and monitor have power to them, but the display isn't showing up on the monitor, it's just black
You need to open the tower and reset the memory sticks still if you get those beeps then try those memory stick one by one or swap the memory stick
Regards
Samson Ved
Dec 03, 2008 | HP Pavilion xl756 (P1358A#888) PC Desktop
No input signal
Hi, there is a posibility that the issue is caused by your system unit. NO INPUT SIGNAL occurs when system unit fails to start properly. One possible reason is the power good signal was not sent back by power supply to mother board. You can check for any shorts or grounded device in your system unit. If you can reseat all the cables (power cable, IDE cable), expansion cards, memory cards even microprocessor that will be good. Another thing you can try is to power cycle your computer. If you are not confident enough to do those stuff you can call your computer vendor and ask for assistance.
Tirzo
Jun 13, 2008 | Acer Aspire L310 (ASL310UD631A) PC...
Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D  Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
