Question about Brother MFC-9440CN Laser Printer
Color How can I darken the color output?
If your on windows (xp), go to printers and faxs->brother printer link->right click properties->general tab-> printing preferences button->advanced tab->setting button
for normal and vivid color mode there are setting
Posted on Mar 25, 2014
Panasonic dmp-bdt220 causes the screen to darken and lighten
It sounds like you have the unit's analog video outputs connected to a TV/Video combo or some time of a recording device. Going through a recording device can cause the image to brighten and darken.
Mar 04, 2014 | Panasonic DMP-BDT220 3D Blu-ray DVD TV
Is it possible to darken colors when printing a copy
You can usually can only alter or darken a print colour from the software program (i.e. Word), then send your document to the printer.
Feb 11, 2014 | HP Officejet 6500A Plus Wireless...
What is the purpose of an R2 filter?
Each filter intensifies its color and darkens others, especially the color opposite on the color wheel. They're not of much use in color photography, unless you want weird color casts, but they come into their own in black&white photography.
For example, a red filter intensifies red and darkens blue. It can make a sky look almost black, making clouds pop out. Similarly it can darken foliage. A green filter on the other hand will brighten foliage.
If your camera can take black&white photos, try taking pictures of a red rose with green leaves with and without the filters. With one combination the rose and the leaves will be the same shade. With a red filter the rose will be bright against the dark leaves. With a green filter you'll get a dark rose with bright leaves.
With digital photography you can achieve the same effect in postprocessing, but some times its easier to get the result in camera.
Apr 28, 2012 | Quantaray 55mm Red R2 Lens Filter
The color on my tv is turning green. It's not totally green but it's becoming green. No matter how I adjust the colors it remains the same with too much green. You can't see the true colors...
It is very common for the color of the lamp to change as it nears the end of it's life. Depending on the bulb itself you may see yellow, green, or blue shifts (I have even seen red/orange). This is due to the diminishing output of the bulb and while you can make some adjustment you will eventually hit the point of failure. The bulb could in fact last several more weeks or even months depending on your use and environment. It is probably a good time to start searching for a replacement now so you can replace it as soon as it dies or just replace it now if the color is too bad to be worthwhile.
May 23, 2011 | Philips Magnavox 9P6034C 60" Rear...
Panasonic 50": lamp blew, replaced it and ever since the screen looks really dim, even through different outputs (cable, HDMI, Component) and with the brightness jacked up, and it still looks really...
you probably need to clean lens and optics in the light engine.Also if it is a lcd projector inside of the light engine in front of the lcd is a glass color filter one for red ,green,blue they can darken and lose or even change color.I would clean optics and check and clean filters.Or you could replace light engine.
Feb 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Darkened picture in perfect border around main
CHECK TO SEE IF YOU HAV THE TEX ON IN THE MEAU IF SO TURN IT OFF
Aug 24, 2009 | Televison & Video
PICTURE SUDDENLY DARKENED AND IS FADING AFTER 4 DAYS
you may have just put it into fade out. find thee fade out control and reverse it the mode. hope that works.
DFD
Apr 11, 2009 | Televison & Video
We cannot seem to make a copy darker??
i would suggest that 1st you do the auto gradation adjustment full adjust under add function /adjustment cleaning then under additional functions look for one that says printer settings you can adjust black density under that setting
Sep 26, 2008 | Canon imageRUNNER C3220 Color Copier
Printing Problem With My HP cp1700D Color InkJet Printer
First clean the cartridge and then go to toolbox and give test print.
Feb 17, 2008 | HP cp1700 Color Inkjet Printer
Almost black printouts.
Have you tried doing a recalibration cycle ? Had trouble here following installing a new blue toner. Everything was TOO intense. Tried turning power on and off a few times and then finally found the route to forcing a full re-calibration.  Ready -->Menu select -->Menu Engine --> >Engine service -->Color calibration.
Now if we could just get rid of these lousy streaks on the side  =<
Dec 17, 2007 | Konica Minolta magicolor 2430 DL Laser...
Brother MFC-9440CN Laser Printer Logo
24 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
