Question about Whirlpool Dryers
After replacing the thermal fuse does it need reseting
I have replaced my thermal fuse and still not working does the dryer need to be reset some how?
  • Whirlpool Master
  • 2,694 Answers
Did you read out the thermal fuse with a meter?if not buy a meter or you'll end up changing parts you don't need,if you changed out the fuse and still have no heat then your old fuse was good and you have another problem,buy a meter,pull off at least one of the wires,set the meter on say 20k ohms,you'll see a 1 one the meter,touch the leeds together and you should see anything but 1,now touch the leeds to the part you're checking with at least one of the wires or both removed,if you see the 1 the part is bad,if you see anything other than 1 the part is good,next time send the full model number off of the machine you're having problems with so whoever is helping you can look up your machine,BUY A METER,don't replace parts you don't need,if you have no heat and you changed out the thermal fuse check the element and the fuses on the heater box,you'll see two red wires going to the heating element,pull one wire off,touch the meter leeds one to each connector on the element,if you see 1 the element is your problem.
Posted on May 05, 2013
Jimster
  • 240 Answers
SOURCE: replacing thermal fuse on dryer
Would need to know what type of unit you have and a model number. On most Kenmore and Whirlpool models they are mounted on the heater box itself. Depending on the type it could be inside the rear panel, or mounted on the floor of the unit. On Frigidaire and other models it mounts to the element case in the rear. Maytags also mount to the element box on the top left inside. Most of the time they have a couple of different looks. On Whirlpool and Kenmore, they have 2 wires running to them, and usually sit away from the thermostat. If its inside the rear panel of these units, it will be towards the top by itself, and could be white or black depending on the age, round or sqaure. On GE, Frigidaire, and their look a likes, it will be small and round, with two wires going to them as well. Most of the time these are metallic in color. Maytags can be black or mettalic, and sit on the sides of the boxes. If this doest help you, please get me the model number and make of unit, and will tell you right where its at. Good Luck!!!!!
Posted on Feb 03, 2008
  • 12 Answers
SOURCE: Whirlpool electric dryer
either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
Posted on Feb 28, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool Dryer Help
Hi theres 2 things that can cause this #1 a dirty vent to the outside. #2 a dirty lint filer , Take the lint filter out & run hot water through it. If water wont flow through the screen, Its gummed up by Bounce sheet residue, Clean the filter . It should be ok
Posted on Jan 21, 2009
kachbibi1
  • 979 Answers
SOURCE: electric dryer wont start
Just replace the thermal fuse for now. You have gotten good use from this machine. But, this is also may be the beginning of the end. Thermal fuses are not expensive either. These things just go out at no uncertain times.
Posted on Feb 03, 2009
  • 210 Answers
SOURCE: Maytag dryer is less than 3 years old. Blew
Have you tried replacing the operating thermastat it's what shuts it off at the right temp and would cause the thermal fuse to go if it is not shuting.off at the right temp. It happens.
Hope this helps.
Posted on Dec 05, 2010
My Maytag double stack gas dryer does not work, the screen is blank(not lighted)
Most clothes dryers have a thermal limiter or fuse, which is a heat-sensitive safety mechanism that shuts off heat to the drum or the power supply to the dryer if it overheats. Unfortunately, you can't replace a thermal limiter once it activates. The only choice you have is to replace it; your dryer won't operate properly until you do.
Although you can't reset a thermal limiter that has been blown, you can reset the dryer's two circuit breakers and restore heat to the drum and power to the dryer. However, after the breakers are reset, you'll still only have partial function of your dryer. For example, it might spin but not heat or it might initially turn on just to shut down after a few minutes. You must replace the defective thermal limiter to reinstate your dryer's full function.
Apr 16, 2012 | Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Is there a reset switch?
There is a replaceable thermal fuse in the dryer.
Unplug the dryer.
Raise the top lid.
The heater is on the back left side.
The thermostat attached to the top of the heater must be replaced along with the thermal fuse located to the right of the heater and down about 2 inches. It should have 2 white wires going to it.
The thermostat and fuse come together in a kit.
Mar 03, 2010 | Crosley CDE6000 Electric Dryer
MAYTAG DRYER PYET444AYW HAS NO POWER...IS THERE AN INTERNAL FUSE?
There is an internal fuse. It is called a Thermal Fuse. It is not resetable it is only replaceable. It is located in the back of the dryer. Unplug the dryer and locate the thermal fuse and replace it. Two wires conect the to it. Also I would check the breaker to the dryer. Thanks and good luck. I you need futher assistance let me know and we will get through this together.
Aug 24, 2009 | Maytag Dryers
Electric dryer wont start
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
GE DVLR223 Not Heating--Is there a reset?
There is no reset. What he did was probably replace the thermal fuse. Why did he not clean it out for ya? Anyway when the thermal fuse goes bad either the whole dryer or the heat won't work. If you can open the dryer up by removing the front panel, you can test your thermal fuse for continuity. If none replace it. While you have the front off undo your belt and remove the 3 screws that secure the rear of the drum (inside drum in middle at back) pull drum out and make sure heat element is not broken. Here is a site for your dryer check it out. www.repairclinic.com/Appliance-Parts?s=t-dvlr223-%3d%3d&z=100 Good Luck
Jan 11, 2009 | GE DVLR223 Dryers
ROPER DRYER WILL NOT HEAT
Put the back panel back, and hope you havent done permanent damage
the back does not come off roper dryers for service
the front does
the back panel serves solely as a mounting point for important fixtures
there is no reset button
there are thermal fuses, if the thermal fuse, mounted on the exhaust duct or fan housing has failed, it must be replaced, but they are not expensive
look like this de074eb.jpgbcb6b5f.jpg to access the dryer mechanism
unplug dryer
remove lint filter
remove 2 screws under lint filter
with putty knife or other blunt blade, depress spring catches at front corners of top cover
raise front cover
remove 1 screw each side of front panel 1/3 from top
remove door switch wires
remove front panel set aside
test all thermostats heater and thermal fuse with ohmmeter, remove 1 wire test for conduct replace wire, no conduct replace
the local parts store will have the part, labelled whirlpool, ~$14 for thermal fuse, ~$40 if heater
examine rear panel reinstall any thing that is dismounted
while the dryer is open
Clean the lint out of fan, fan housing, ducts
airflow blockage is the 99% cause of thermal fuse blowing, some lint always gets past the lint screen
Oct 29, 2008 | Kenmore 63942 Dryer
Hotpoint CTD 40
Thermostats do not have a reset
IF the dryer has failed by overheating, the device is called a thermal fuse, it is a one-shot protector, and needs to be replaced.
If the thermal fuse has blown the dryer is likely {expletive deleted} with lint and needs to be cleaned.
STILL require make and model details for replacement instructions
Oct 08, 2008 | Dryers
Maytag dryer ... where is the thermal reset button???
thermal cutouts, thermal fuses, thermal resets, are not resettable, they are a one shot, last ditch, protective device.
fail once - wear,
fail twice - you must clean the lint out of the fan, and exhaust duct before the house burns down.
the thermal reset is a device like this 2ce0a6a.jpg, or this61220a5.jpg fitted on the fan housing.
conduct good,
open circuit fail and replace.
the local parts guy has them, there are only a few that fit multiple models it does not matter what brand is on the packet
dirty
4a10230.jpg clean
0787faf.jpg dont clean
a869f54.jpg the exhaust ducting must be clean to the eternal wall vent
Jul 22, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer reset?
NO RESET BUTTON, BUT THERE IS A THERMAL FUSE LOCATED ON THE BACK NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM WITH TWO WIRES ATTACHED TO IT. CHECK FOR 120 VOLTS AT THE TWO TERMINALS. IF YOU HAVE 120 VOLTS THERE, THE THERMAL FUSE IS BAD. REPLACE FUSE AND CHECK FOR RESTRICTION IN THE AIR FLOW. ALSO, IF YOU HAVE A THERMOMETER THAT CAN MEASURE TEMPS BETWEEN 100 AND 200 DEGREES, CHECK THE TEMP AT THE EXHAUST ONCE THE DRYER IS OPERATING AGAIN. IT SHOULD CYCLE OFF SOMEWHERE AROUND 170 DEGREES. IF IT GOES OVER 200 DEGREES, REPLACE THE CYCLING THERMOSTAT.
Apr 09, 2008 | Whirlpool GGW9200L Gas Dryer
Open Questions:
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
