Question about Refrigerators
Caravell ice cream freezer, 12 unit, the cool choice.
Bought the freezer on line. from over seas. product name is iskrem.
dididsaythat
  • 291 Answers
SOURCE: Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Posted on Sep 06, 2007
aborcass
  • 2651 Answers
SOURCE: Freezer doesn't keep ice cream frozen
not being able to keep ice cream is not good, before doing anything ck a few things. make sur e to pull out unit and vaccuum under and behind unit, if it cant breath it cant freeze. check in back by compressor, is the fan running to cool the fan??? if the compressor is on so should the fan be. next id look behind the freezer wall for excessive build up of frost( it might even be buildin up with ice throughthte back wall, inwhich case you have a defrost issue
Posted on Apr 02, 2008
IFIXALL
  • 868 Answers
SOURCE: We have a Whirlpool gb22dk
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Posted on Jun 09, 2008
kevin000
  • 1847 Answers
SOURCE: JCD2389GT
Go through this link....
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on Aug 12, 2008
SOURCE: FREEZER ICED OVER, LOWER COMPARTMENT NOT COOLING
Well, if the service person said the defroster is not the problem, there must be a good reason. But, I would go with a faulty defrosting system. Most likely suspects are the defrost timer and the defrost heating element.
Posted on May 05, 2009
Gets only cool not cold
the thermostat is supposedly right below the BLACK switch knob of the unit.
it should look like this if you open the unit up.
but before you open the casing, try to refer to CuisinArt's warranty terms even if you lost the proof of purchase for the unit.
good luck
Jul 27, 2008 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
My C713 water cooled yogurt machine keeps locking and only works when cleaned but only for a few hours then it locks again. Does anyone know why?
The temperature of the product is too high. If the product either in the cylinders or the hopper goes above safe temperature for too long the freezer will lock until the product is removed and the unit is properly cleaned. I would guess it's the hopper temperature because I think you would notice if the product that's dispensed is above 40 degrees. Soft Serve Parts C713
Aug 01, 2016 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Gongly soft ice cream machine won't work. Beeping sound when power is turned on. What is the problem?
manual control soft ice cream machine, View carpigiani ...
gongly.en.alibaba.com > Product Categories > Soft Ice Cream Machine
manual control soft ice cream machine,US $ 0 - 1000 / Unit, Air-Cooling, CB, CE, ... Brand Name: GONGLY; Model Number: BQL-838; CERTIFICATION: CE/CB, ...
Machine glace italienne www.gongly.eu - YouTube
? 6:48
https://www.youtube.com/watch?v=D7c2Hiwi6FQ
Jan 3, 2011 - Uploaded by TvSTORE
Machine glace italienne www.gongly.eu. TvSTORE ... Jin Li Sheng Fry Ice Cream Machine Fried Ice Cream Machine Fry Ice Pan Machine ...
Hot Sale Jin Li Sheng BQ322 BQ332 Soft Ice Cream ...
? 1:14
https://www.youtube.com/watch?v=ChUllkdJMlc
Jan 14, 2016 | Ice Cream Makers
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
Loose fill tube on ice maker Maytag side by side
Please look around your refrigerator fresh food section door frame for a model number. I believe the reason water is leaking inside freezer is a defective water control valve that you attached to with water line on back of most refrigerators.
I am here to help just let me know, Thanks Sea Breeze
E-Mail
Nov 20, 2012 | Maytag Refrigerators
Need a product user's manual for Maytage side by side bottom freezer refrigerator Model no. is 12670XEB3. Can't seem to find it on line ( model no. that is)?
If you ever need a Maytag user manual Click Here=> Manuals & Literature
Having your model number is very importatnt as having a serial number will not work, Thank You, Sea Breeze
Sep 12, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
