Question about Exercise & Fitness
Healthrider h550i controls
The only button on the control panel that works is 2 on speed. No incline, no other speed, no fan, no anything except 2.
SOURCE: My console does not allow me to change the
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Posted on Oct 14, 2009
Testimonial: "He asked the right question."
outfield502
  • 79 Answers
SOURCE: Healthrider H550I show 20 mph then slows down to crawl
OK two things, first is that you must check if the belt is in good condition and the deck also. second, we turn to the recommendation, review the motor controller if any diode or MOSFET is bad, and maybe check the main motor has to re-coiling
Posted on Feb 05, 2010
  • 218 Answers
SOURCE: My Healthrider H550i doesn't want to stop
let it go through the cycle it is trying to recalibrate itself. it will stop once it's done,
Posted on Aug 10, 2010
  • 84 Answers
SOURCE: incline motor stays on going
could be bad incline sensor or c/board is going bad. one more try bipassing the board with power to the incline motor fully powered 18volt batt will or higher will move the motorby flipping thr wires on the bat the incline should go up and down. if working ok then check board
Posted on Mar 18, 2011
  • 5603 Answers
SOURCE: I have a Epic 400mx
Most of these use a membrane keyboard with silver inked conductors on plastic membranes that are pressed together through a hole in an insulation layer between the two printed membranes. When these keyboards start to go bad REPLACEMENT is really the only solution.
Posted on May 20, 2011
Part of treadmill buttons won't work?
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Aug 20, 2016 | HEALTHRIDER T650I Treadmill Front Roller...
Healthrider 15.5 won't run,motor makes alittle grunt,turns alittle but won't run,incline motor works
hi Geoff,
if it is contain belts please check.and try to move running belt it must run freely.sometimes it must stuck because of long idle time.
in electronic circuit the large smoothing capacitors can be damage because of long idling time too.
let us know the status,
regards.
nuwan
Jan 10, 2014 | Exercise & Fitness
Healthrider 500i. The screen lights up with no belt, fan, or key pad response. I manually started the belt then it wouldn't stop or change speed.
adjust the Reed Swith see the diagram:RESET, clean, and tight cable connector.
2) Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Aug 28, 2012 | HEALTHRIDER Pro H500i Exercise Workout...
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Healthrider will turn on and is in demo mode. will not do anything else.
1) IF THE MACHINE ONLY RUN IN DEMO MODE, TRY TO RUN IN NORMAL POSITION.
2)PUSH AND HOLD ON THE STOP BUTTON BY 5 SECONDS.
3) IF THE PROBLEM PERSIST, TRY TO TIGHT THE FLEXIBLE CORD FROM KEY PANEL VS DISPLAY BOARD.
4)TIGHT THE DISPLAY BOARD VS LOWE BOARD(MAIN MOTOR BOARD)
5) IF THE PROBLEM PERSIST THE MAIN MOTOR CONTROLLER BOARD IS PROBABLY FAULTY.
6)bEFORE TEST THE MAIN MOTOR.
SINCERELY.
12_13_2011_9_19_40_pm.gifSeethe block diagram
Jul 19, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
My son folded my healthrider s300i while it was in an incline position now the incline doesnt work is there a reset to fix this?
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Jun 23, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Incline motor stays on going down, and will not respond to the controls. healthrider R 60
Mar 16, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
Console lit but none of the pushbuttons function except for incline and there is no motion. The speed switch has been alligned to 1/8" gap. Plesae help with advise. Thanks.
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
Jul 31, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
Feb 05, 2010 | Exercise & Fitness
Exercise & Fitness Logo
47 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
