Question about Western Digital My Passport Essential 500GB USB - Blue, with grab-and-go USB Dock and WD ... Hard Drive
Driver uninstalled and secure key for WD My Passport WDBACX0010BSL-01 is not being asked any more, so it is blocked.
Cannot find any downloadable driver for iMAC OSX
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: i can't open my WD
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on Jun 15, 2011
I have a WD Passport External Drive. (WD1600ME-01) I know it works but all the wires I have that fits the Drive don't seem to work. When I connect the wires, I can hear the Drive go on and shortly aft
You may first want to try disconnecting any other USB devices, to guarantee that the drive is the only power-drawing device. Drives typically need all 500 mA that a USB port normally provides.
Cables do wear out, especially those handled often. Mini-USB cables are pretty common and can easily be replaced.
WD Support Downloads My Passport My Passport Essential
Dec 02, 2014 | Passport Computers & Internet
My wd passport wont open the details and files ....it is there on devices and printers but wont open the files in it..my wd passport is wdbacy5000abk-01
What hapened to the drive before it stopped working, does it fell down? try to listen to drive very carefully, does it spinning ? are there any abnormal noises e.g click... or beeps ?
Feb 25, 2014 | Western Digital My Passport Essential...
Install USB 250GB External Hard Drive
Heres what to do.
1st go to this link ------ > Click Here
Next step is to choose your product type.
After choosing your product just click on the link WD SES DRIVER to download the driver of your product.
after downloading it, install it in your pc.
After installing the PC, insert your WD PASSPORT 250GB External hard drive to test if the driver you download works.
Goodluck. Hope my solution will help you. Please give me feedback regarding my solution on your problem. Thank you very much.
Jul 02, 2011 | Western Digital WD Passport 250GB Portable...
When I connect my wd passport, this massage appears "usb not device recognized". although the cable is working with other devices and the wd passport is also working on other computers (not my...
there is NO problem on you external hard drive..the problem is in your own computer USB port..try to uninstall the driver of your usb port.then try it again.
Jun 15, 2011 | Western Digital My Passport Essential 160...
I have a WD1600ME-01 hard drive passport. It was working fine but suddenly my laptop is no longer recognizing it neither my PC. when I connect it the drive light starts to blink and I hear a continuous...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jan 02, 2011 | Western Digital WD Passport 250GB Portable...
My wd passport is set to read only under sharing and permissions how do i fix that?
Is this a Windows, Mac, or Linux / Unix system?
Sometimes you need to uninstall the drivers and reinstall, reboot and all is OK (i've seen this in Win7).
Try to check WD's forum's for some info specific to your passport drive.
Nov 30, 2010 | Western Digital Passport WDXML800UE...
Accidently uninstalled Western Digital program
google western digital and dowload the drivers again, then reinstall from disc if you have one! (do this with the drive un-plugged) when you then re-boot and plug it in all should come right!
Sep 27, 2009 | Western Digital Passport 320GB External...
Western Digital My Passport Essential 500GB USB - Blue, with grab-and-go USB Dock and WD ... Hard Drive Logo
50 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
