Question about Saturn 2007 VUE Hybrid Base
Saturn p2172 Out of nowhere the engine light comes on. Went to autozone they said it was p2172 and then on the computer it says nothing. Then they said it was a tps issue throttle issue and I can only get it a gm dealer. The engine light did go off today it just seems odd. The car has been good to me
SOURCE: 2002 Saturn Vue V6 Loss of Power
Yup. The throttle body connectors have a history of failing on these cars. Replace the throttle body and the wire connectors that go to it, and you're back in business. Not terribly difficult and you can get the parts from any dealer. Saturn actually has a bulletin out on this problem but they won't cover it unless you're under warranty - no recall for this.
Posted on Mar 05, 2009
  • 38 Answers
SOURCE: myservice engine light came today rogh in idle at light rpms seem a little high this is a 98 saturn sl2 I think engine is a 1.9
the check engine light means that a code has been set. the code will reference a faulty system that must be diagnosed and repaired. sorry for the vagueness, but there are e gads of codes that can cause the rough idling
most aftermarket parts places will scan the car for free. this will give you an idea of where to start.
Posted on May 12, 2009
  • 166 Answers
SOURCE: Interminently Losing Power 97 Saturn SC2
Hmmm, as to on-again, off-again engine power, it may be the electrical connector that runs from the electronic control unit. Read this diagnostic article, as it seems similar to your situation:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Engine_System_Engine_Abruptly_Quits_Periodically_While_Driving.htm
You might also want to read up on engine overheating since you say you seem to have that:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Engine_System_Engine_Overheats.htm
Hope this helps!
Brad
Posted on May 26, 2009
  • 72 Answers
SOURCE: Service Engine Light in 2001 Saturn SL2
Depending on the code. Let me know what the code is, and I will tell you what it affects, and how serious it is.
Posted on Jun 25, 2009
SOURCE: 2005 ion power steering problem
remove electronic power steering (EPS) motor. remove the 4 bolts that hold on the motor housing. remove the housing. using a tooth brush, clean out the 'brush' dust from between the commutators. don't use cleaner spray as you might degrease the bearings. don't use anything metal to clean out the dust you might scratch or nick the commutators.
this solution has worked for over 500 miles for me. I'll keep you posted.
Posted on Sep 07, 2009
Saturn l200 engine light is on and when going uphill loosing power and the light blinks
When the Chk eng lite comes on the engine computer stores a fault code for the problem, you now need the fault codes read, this is called an OBD2 system fault code test, you can get it done free at any Autozone or other chain parts store like them.
Nov 30, 2016 | Saturn Cars & Trucks
P2172
sensors go bad with age. if the light stays off it will eventually come back on. It is best to do repairs right away to avoid damage elsewhere.
May 05, 2013 | Saturn 2007 VUE Hybrid Base
My service Light comes on and stay on after the car is on idle for 1 to 2 minutes. Is not on when you first start the car. I took it to a mechanic and he can;t find nothing wrong with the car, no computer...
If the light comes on then there is a code. the shop you went to may not have the updated software. try another shop. go to a parts store. they can read the codes.
Feb 07, 2011 | 2003 Saturn VUE
Check Engine Soon light has come on. How do I check for codes?
Take the car to an autozone and they can read the trouble codes stored in the computer.
If you do not want to go to autozone, take the car to a dealership and the codes can be read by a qualified mechanic. the check engine light means a trouble code has been stored in the vehicles computer.
Oct 30, 2010 | 1994 Saturn Sl
My 2003 saturn vue service ebgine light stays
The CEL (Check Engine Light) will not go out until you hook up a OBD II scanner to your vehicle and erase the code. If it comes back again after you erase it than either the original problem still exists or you have a new problem. You can go to your local AutoZone store and they can hook up a scanner and erase your code for free.
Jun 05, 2010 | 2003 Saturn VUE
I have a 2006 Saturn Ion...the check engine light comes on and off from time to time. It does it pretty regularly, but I can't tell any difference in the car's operation. The check engine light came on one...
You have an intermitten problem, and 10 to one it's in the evap emissions system. With the light coming on and off the computor doesn't have time to store a code. When the light comes on and stays on, then go back to autozone and get the code.
Mar 20, 2010 | 2006 Saturn ION
CHECK ENGINE LIGHT
there are over 200 system faults that turn the check engine light on, have the systems computer tested, there should be a trouble code present to ID the fault(s)
Sep 28, 2009 | 2004 Saturn VUE
3 differnt codes came on on my saturn vue
abs control module is probably bad wont show codes
Jul 21, 2009 | 2004 Saturn VUE
"Service Engine Soon" warning light
The "service engine" light come on in about 80% of older cars quite frequently. Usually, it means nothing being related to some emissions component or similar. You can shut it of with a rented (for free,) tool at Autozone. The tool is a code-reader, and can also tell you what the specific cause is, as well as instruct the on-board computer to simply turn off the annoying light. Odds are it'll come back if you don't fix whatever trivial B.S. it is complaining about. Best advice: Unless it's something major, just live with it like everyone else. - Good Luck, John
Jun 03, 2009 | 1993 Saturn SL1
2003 Saturn L300 indicator lights stay on: ABS, SES...etc
first problem, went to autozone. the guy that looked at your car was making pizzas last week. they pull codes and sell you every part you will buy. take the car to the saturn dealer and replace the bcm.
Mar 02, 2009 | 2006 Saturn L300
Saturn 2007 VUE Hybrid Base Logo
215 people viewed this question
Top Saturn Heating & Cooling Experts
Tom Chichester
Hank Orsel
Level 1 Expert
David Ellis Rhea
Are you a Saturn Heating and Cooling Expert? Answer questions, earn points and help others
