Question about Garden
Briggs Jet clogged on carburetor
If u know where its cloged poke it out with a sewing nedle and use a scotchbrite pad to clean jet . flush gastank if carb not conected to tank a inline fuel fliter could help
Posted on May 05, 2013
Engine ideals but wont rev
Carburetor has a blockage at the main jet. Recommend carburetor overhaul.
Apr 06, 2014 | Briggs & Stratton Garden
Prime the engine and runs for a few seconds then quits
Sounds like Jet in Carb is clogged.
Drop the Center bolt on the Carburetor Bowl and clean out the holes in that hollow bolt
Aug 24, 2013 | Briggs & Stratton Garden
Float level
sounds like Jet is clogged
Take out center bolt on Carburetor bowl ( 1/2" socket) and clean the holes in this hollow bolt
Aug 23, 2013 | Briggs & Stratton Garden
24 hp briggs intek starving for fuel
Always check for jet. 90 percent of the time it is clogged. Remove the bowl and float and it is the center screw.
Jun 10, 2012 | Briggs & Stratton Briggs Stratton Intek V...
A briggs and stratton 450 series 148cc on a moter mower.The engine fires up after priming then dies.The air filter is fine so is the spark plug,could it be the two small springs behind the carbie?
More than likely, it is the main jet is partially clogged. That is the brass bolt that holds the float bowl onto the body of the carburetor. Remove this bolt and washer and clean it well. Use no metal objects to clean it.. Make sure the bottom hole and the side holes near the top are clean and clear.Carb/choke aerosol spray should do the job here. Use no metal wires or scrapers on the jet. Clean until shiny, reinstall and try starting the machine.
Apr 24, 2011 | Briggs & Stratton Garden
My riding lawnmower will only stay on momentary. Gas is clean and spark plug is clean? The gas filter did have some water? What else can I check?
Check the brass bolt (clean it thoroughly) that holds the float bowl on the carburetor. It is the Main Jet of the carburetor also and without a fuel filter and/or letting fuel evaporate in it causes the very small holes in it's bottom and sides to clog. Use no metal objects when cleaning/scraping. Wood or plastic only. You don't want to change the precise diameter of the fuel metering holes inside the jet. Clean it till it is shiny and reinstall.
Apr 05, 2011 | Briggs & Stratton Garden
Gas Push Mower - Briggs & Stratton, will start but run for
The jet in the bottom of the carburetor is clogged up. The engine will prime but after that fuel is burned off, the engine stops. The jet is not allowing fuel to be sucked into the engine.
Sep 29, 2009 | Garden
My Yard Machine W/a 6hp B&Sengine will crank & run on starting fl
Most likely you still have a jet inside carburetor that is clogged how did you clean it soak it in carburetor cleaner? Did you take out jets to make sure they are clean
May 05, 2009 | Briggs & Stratton 66set Panzer Tractor...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
