Question about Mitsubishi WD-73827 73" HDTV DLP TV
How to get closed caption
Tried to get closed caption on the tv can not come up with the how
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2,3..now u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Dec 10, 2010 | Broksonic TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
Nov 27, 2008 | Computers & Internet
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Closed captioning
try uplugging the tv for a day if the captioning is still in customer menu then try to find a universal or replacement remote this remote may have dedicated captioning key there may be a button sequence on the front of the tv that will reset the customer settings
Dec 09, 2006 | Orion STV2763 27" TV
Mitsubishi WD-73827 73" HDTV DLP TV Logo
15 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
