Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Solution tank not sucking water
I noticed that after shampooing the solution tank was still full. I called and the representative said that it needed someone to fix the suction part.
  • Official Brand Answer
  • 315 Answers
Hi Arty5153. I'm sorry to hear you're machine isn't using the formula. I know how frustrating this must be.
I understand you did do some troubleshooting steps, but I want to provide you with a link to our complete list.
Posted on May 09, 2013
  • 25 Answers
SOURCE: BISSELL PRO HEAT X2 CLEAN SHOT
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Open the door and you will probably find it is clogged with hair, carpet fibre., etc.. Clean this out and you will hopefully have suction again.
Posted on Sep 18, 2009
fathitkf
  • 1871 Answers
SOURCE: no suction of the water from carpet after soap is applied
Hello :
1: A vacuum pulls air through the bag, then through the tube attachment and then through the base (with the spinning agitator brush).
2:Check for signs of suction. Remove the tube attachment from its cradle and, after turning on the vacuum, put your hand to the end of the tube. Is there any suction at all? If there is a little bit of suction then you may have a clogged air tube.
3:Check the vacuum bag. It may be very full. If it is then remove the bag and replace it with a new bag. Check the suction power again. Has the suction improved?
4:Check the tube attachment. Completely remove it from the vacuum. You usually have to twist and pull the tube attachment out of place at the point where it connects to the back of the vacuum. Check the suction power again. This time you place your hand on the vacuum right where the tube used to come out of the back of the vacuum. Has the suction improved?
5:If the suction power has improved then you probably have a clogged tube. Dog hair, people hair, leaves and more can get lodged in the tube slowly over time and then suddenly block the tube completely.
6:Clean the tube by first trying to shake the debris out of the tube. If this does not work then go outside and run a hose through the tube. Use a pressure nozzle if you have one. Run the hose through one end of the tube. Then run it through the other end. Repeat until the debris is disloged. Dry the tube and then reattach to the vacuum.
7:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
8:Check the air hose in the base of the vacuum. This hose is usually pretty short and you can see if there is any blockage. If you see blockage then try to remove it. You may need to reach into the hose with a tool (like a screw driver or something long).
9:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
10:If you made it to this step then you may have a problem with the motor on your vacuum. If this is the case then you will need to take the vacuum in to a repair shop.
Things you will need :
1 Philips screw driver
1 flat head screw driver
Warning :
# Always unplug electrical devices before you work on them.
# Never work on electrical devices around water or when you are wet.
I hope this will help .
please rate !
Posted on Apr 27, 2010
SOURCE: water suction
Here's what I did. On the top of the water bucket there is a red oval screen, remove and clean the screen and replace. Also, next to the screen is an oval opening which meets up with a black oval gasket on main unit. Inspect the gasket and replace if dry or cracking. Otherwise, if it looks good, reseat the gasket (it fits into some grooves). When you fill the bucket and put the the top on, put it in the machine and make sure it is making good contact against the gasket. This worked for me. I also found a repair manual for these units that could be helpful located at: http://www.bissell.com.au/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on May 24, 2007
tipstir
  • 67 Answers
SOURCE: not sucking up dirty water
Sounds like the suction motor is not working correctly. Either clogged with dirt or objects or it is failing.
Check this first:
Not suctioning properly, first check the motor duct gasket. To check this, first remove the tank and place your hand over the rubber square opening.
If your machine does have suction at the duct, continue to check the following:
Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE
ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced.
Check the Tank Lid and Tank for damage.
If there is no suction there, please take your machine to a BISSELL Authorized Service Center for inspection.
Posted on Jul 31, 2008
  • 14 Answers
SOURCE: water not dispensing
Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
Posted on Jun 07, 2010
My shampooed won't pick up ythe water
does your shampooer have a cap on the shampoo tank. Usually you take the cap off to let the shampoo out while shampooing and to pick up the water you put the cap back on to create a vacuum to suck the water off the floor..
Jul 01, 2017 | Vacuums
How do I get the Shampoo solution tub unclogged so it mixes with the water to clean my carpets.
You can try adding hot water, but your best bet is to remove the tank and hose and flush them well with hot water to clean them out.
Jan 02, 2015 | Bissell Brushroll Proheat 2X 8920 9200...
The shampoo is dispensing too much shampoo, it is empty in no time
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
Sep 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
My shampooer only sprays a single stream of shampoo and water whenever I use it on the carpet... That and I can't get it to lay a nice even layer of shampoo to soak in and then pick it up...it always does...
You are probably missing the foam screen on the tank outlet. There should be a plastic disk with a fine screen in it on the tank outlet. If the screen is missing, foam will not be produced; and just soap water will be sprayed out. Sometimes the screen assembly can be found in the end of the shampooer hose.
Nov 01, 2010 | Kirby Shampooer Shampoo Hose G3 Ultimate...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My steam vac stopped sucking the water up
make sure the lid on the dirty water container is on tight and the tank itself is locked into place, also check to make sure the clear window in the front of the machine is tightened down firmly
Oct 20, 2009 | Hoover F5858-910 SteamVac Vacuum
Vac not sucking up water
its supposed to, it means you need to dump out the tank. Its a safety feature that keeps the water out of the motor. if its lifting up due to foaming, than try using the original brand shampoo
Jul 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Oct 20, 2008 | Bissell 9200 Upright Vacuum
Suction
Opening that door and attaching the hose will let the suction go thru that hose. So if when you removed the hose, if that door isn't closed tight will cause you to have a suction problem It has to seal and have no leaks. The other thing when be a problem with the recovery tank not sealing when you put it back on. Other then that, any air leak will cause a suction problem.
Apr 19, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
