Key setup I tried to enter the setup key but it said invalid setup key
  • 7,627 Answers
Setup key in what? What are you trying to setup? It would be helpful if we knew the Make, Model of Laptop and the OS you are using.
Posted on May 05, 2013
Cisco AM10 Error "Invalid Key Manual"
Try to reboot and install it again after delete the router setup from device manger..
Feb 13, 2013 | Computers & Internet
Invalid cd key windows XP
Make sure that you enter it EXACTLY as the key reads. All capital and lowercase letters, O and 0 look similar, B and 8 look similar. Try it with dashes and without dashes.
Good Luck!
Jun 03, 2012 | THQ Red Faction Guerrilla for Windows
How to set code remote for symphonic
These are the setup proceedings.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 19, 2012 | RCA 3-Device Universal Remote with...
I have a Acer AT3220A television and I want to control it with my Telus remote (AT6400 Universal Remote). Do you have a code that works? Thank you.
hi,
do the following setup in ur remote
1. Turn on the device that you want to assign to a
mode key.
2. Press and hold the appropriate mode key (TV,
DVD, or AUX) on the remote, and then press and
hold the OK key.
3. Release both keys and the mode keys blink twice.
4. Enter the first 4-digit (1041,1192 any one first) setup code for the device using
the numeric keys (0-9) on the remote. The mode key
blinks three times to indicate that the code entry was
accepted.
Notes:
• When an invalid code is entered, the selected
mode key displays a long flash to indicate that
you have not entered the code correctly.
• Should the remote time out before you complete
the code setup, you must start over. This is
indicated by one long flash of the red LED.
5. Point the remote at the device, and press POWER
to test the device.
6. Did the device power off?
ok
Dec 15, 2010 | Acer Televison & Video
Invalid configuration information-please run SETUP program
Here is what you do, go into the BIOS setup, usually you press the DEL key OR F2 or whatever your one is, IT should say on screen as it boots up.... it says "Press YOUR- KEY Key for SETUP". So, get into setup, using your manual ensure it is set correctly. Then SAVE SETTING and exit All should be good now.
Feb 06, 2010 | Dell INSPIRON 6000 CENTRINO...
Im trying to use my digital frame and it says i need a network key. i entered my pass word and it says hexidecimal form invalid. how to i get the hexi form of my password
You need to bring up you router setup. Under the wireless security you will find your network keys. This is what you need to add any device to the network. Your password only alows you to access the router setup itself.
Dec 05, 2009 | Belkin (F5D7230-4) Router (587009)
Trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Sep 05, 2009 | Sherwood RX-4109
    I need the remote code for the Vizio HD VX32L so that it works with my AT&T Uverse remote control. Everything works but the "mute".
    VIZIO HDTV 1004
    1. Power on the device the Member wants to program.
    2. Locate the four digit setup code for the device the Member wants to program from the Manufacturer Code List section.
    3. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
    4. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
    5. Release both the Mode key and the OK key at the same time.
    6. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
      • The Mode key will flash three times indicating correct entry and return to normal operation.
    7. Point the remote control at the programmed device and press the Power key once.
      • The device should turn off.
    8. Repeat steps 1 through 7 to program other devices if needed.
    9. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Jun 28, 2009 | Olevia LT32HVM 32 in. LCD Television
    We have deleted booting passward
    Try to hit ESC key instead of ENTER key.
    Hope this trick works for you.
    If not consider the old passion way disconnect the cmos battery for the meantime then plug it again this should reset the password but it more tedious.
    Apr 13, 2009 | Toshiba Tecra 9000 Notebook
    Taking forever to reinstall XP Home Edition
    To clear the NVRAM, perform the following steps:
    Restart your computer.
    At the first text on the screen or at the Dell logo, press the <F2> key every three seconds until the message Entering Setup appears.
    The System Setup screen appears.
    Press the <Caps Lock> key, the <Scroll Lock> key, and the <Num Lock> key to light up all three lights on the keyboard.
    Press the <Alt> and <E> keys at the same time.
    The system will emit a beep tone to indicate that NVRAM has been cleared.
    Press the <Esc> key, and then press the <Enter> key to save the changes and reboot the system.
    Proceed with the installation or troubleshooting that you were attempting
    Apr 03, 2008 | Dell Dimension 3000 PC Desktop
    Computers & Internet Logo
    49 people viewed this question
    David Payne
    David Payne
