Question about Hitachi Director's Series 65XWX20B 65" Rear Projection Television
Picture distorts randomly and resolves by turning off and back on
I have a problem that randomly starts as a mild wavy pattern and progresses with worsening waveyness (horizontal waves) and the colors distort usually to a greenish hue. It tends to start at the bottom of the screen and work its way up the screen as it intensifies. The problem is becoming more frequent in the last couple weeks. I can turn off the tv and immediately turn it back on and 80% of the time it will rectify the problem completely. It may start in again with in a couple minutes or function perfectly for several hours. Any ideas? There's a big sale at best buy...do I need to attend it? pedchiro
  • pedchiro Aug 09, 2007
    are there local repair techs? Arlington texas.
  • 398 Answers
I do wish sgregg would stop giving advice on things he obviously knows nothing about. The 65XWX20B is a standard projection set and does not have a lamp in it. It has 3 separate picture tubes. The power board is not the problem either because you would get no picture if it failed. You most likely have a convergence IC which is on the verge of failing and is starting out OK but acting up when it starts heating up inside. A good tech will replace both STK392-110 IC's with the newer updated STK392-150's, realign the convergence circuits and be done in about an hour and a half. When I do a housecall for a set like that I charge $150, but techs in your area will vary so ask around.
Posted on Aug 10, 2007
    Sniper:
  • 133 Answers
Well its probably gonna hurt your feelings and your wallet because its gonna be a powerboard problem which will cost a pretty penny or your lamp which will cost around $200. Try and take it in to a serviceman and itll be around 60-70 bucks just to look at it. HOW MUCH DO YOU LOVE YOUR TV? remember people need parts too. you could make some money on ebay for the parts if you decide to hit up the sale.
Posted on Aug 09, 2007
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
How do I fix wavy lines on Hauppauge Wintv hvr950q?
Are they wavy lines throughout the picture or are they just wavy on the side? Waving picture is usually caused by poor power supply filtering. Wavy lines throughout the picture are caused by interference. Try moving the device away from the computer with an extension USB cable it may be picking up interference from the surrounding electronic devices. It could also be defective.
Oct 19, 2014 | Hauppauge WinTV-HVR-950Q (1191) TV Input
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
Jul 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Wavy horizonal disturbance in picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Televison & Video
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
Picture quality in cable mode only, watching dvd picture is
Herringbone pattern?
House stray AC 60hz signal is getting into the cable b/c the shield is not properly grounded. Call the cableguy
Mar 26, 2009 | Samsung 50 in. Plasma TV
Hitachi Director's Series 65XWX20B 65" Rear Projection Television Logo
99 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
