When cleaning my compaq presario sr1620nx,I removed the cpu fan& everthing behind it. Now that's the only thing that works. What the heck!!?
  • Computers & ... Master
  • 5,660 Answers
A) Did you FOLLOW Anti-Static Procedures?
If you are not aware of Anti-Static Procedures post back in a Comment.
B) Did you bump a Ram Memory module ('Stick') loose, or more than one?
Following Anti-Static Procedures, remove all Ram Memory modules, and clean the gold plated contact pins with a pencil eraser.
There is a procedure for this; if interested post back in a Comment.
To KNOW that the Ram Memory module/s are seated correctly, and tightly; is to remove it/them, and reinstall.
This way you are Assured. Visual inspection alone will NOT do.
Plus you have cleaned the contact pins at the same time.
C) Power Supply's are evil..........
They wait until that ONE unsuspecting moment, and when your back is turned they shoot cr@ps.
At least that is the way I'm sure it appears to some people
LED's light, and fans spin?
I don't care
A) If ALL of the LED's were lit up at once, they would use less than 1 Watt of power
B) EACH fan uses 2 to 3 Watts of power
C) A typical Processor (CPU) can use Up To 130 Watts of power.
Just depends on what Processor it is.
HP Support > Compaq Presario SR1620NX Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=1127351
Product information > Product specifications > Compaq Presario SR1620NX Desktop PC Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00472092&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=1127351
Processor (Base Processor):
AMD Sempron 3400+
(2.0GigaHertz)
Motherboard uses the Socket 939 processor socket.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=1127351
http://en.wikipedia.org/wiki/Socket_939
Cuts the list down to one..........
Palermo Core technology, and the 90NanoMeter architecture,
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors#.22Palermo.22_.28Socket_939.2C_E3_.26_E6.2C_90_nm.29
Up To 65 Watts
Static shocked?
Not much to say
Ram Memory procedure didn't do the trick?
Then suggest checking Power Supply,
Or using a temporary Power Supply.
To check is to test the 3 main voltage power rails, with a multimeter set to DC Voltage;
OR,
See if there is a KNOWN to be good, Compatible power supply you can use for a temporary test unit.
NOT stating rush out, and buy a replacement unit.
Stating test first.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on May 05, 2013
honest1abe
  • 72 Answers
SOURCE: compaq presario 6000 turns on but won't boot up.
Marj,
Even though you said no pins were bent, my guess is that one of the pins either bent or broke off completely.
I am assuming that since you were inside cleaning, the computer is out of warranty.
Try examining the CPU (thingy under the fan) for any bent pins or broken pins. The alignment back into the mother board is crucial. Usually there is one corner with no pin or the corner is squared off to indicate the positioning of the chip in the pin holes.
Reseat the CPU and make sure it goes all the way down flush to the motherboard.
Usually there is a lever beside the CPU that you can lift that makes it easy to install or remove the CPU. It is called a Zero Insertion Force (ZIF) lever.
Personally, I'd recommend a professional or very knowledgeable and experienced friend help you reseat the CPU. Otherwise, you will need to replace it and they are not cheap.
However, if the CPU is damaged beyond repair, you might find a good USED one online at a decent price.
Posted on Dec 28, 2008
  • 16 Answers
SOURCE: compaq presario sr2030nx desktop-no beeps no video
This sounds like a problem on the motherboard. This can be determined quickly buy most technicians. Be certain you are using a good voltage regulator. This is common problem if there are voltage spikes. Happened to me.
Posted on Dec 17, 2009
  • 160 Answers
SOURCE: Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Posted on Dec 22, 2009
  • 4 Answers
SOURCE: upgrade cpu on pavilion 6630
just because the 750mhz cpu is socket 370 that doesnt mean it'll work...the 750 mhzcpu is probably a FCPGA 1.75 volt w/ 100mhz fsb and the original cpu is of the PPGA package, 66mhz fsb, 2volts, etc. i think itll only work with pc100 but im not sure...as for the video i have no clue...
Posted on Feb 23, 2010
  • 1768 Answers
SOURCE: powers up and cpu fan is racing but no boot,
This may be due to a CMOS mother board battery. I know that some tech or expert say that you can still boot without it but my experience is that if the CMOS battery is below 3.4 volts it may or may not post or boot. This battery is about the size of a quarter usually found at Walgreens or Walmart for about 3.00 dollars.
Posted on Apr 06, 2010
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
SR1620NX Under Device Manager, SM Bus Controller needs a driver update. What exactly is this that i...
Hi, I went to the HP page for HP Compaq Presario SR1620NX -
and searched for SM bus controller.
There was a help page that came up and looked like it may work.
Try:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02522280&cc=us&dlc=en&lc=en&product=1127351&tmp_track_link=ot_search
It looks like the next step is to determine which chipset you have and go there (intel, AMD, nvidia) HP offers a link to these websites at the bottom of the article.
Have fun, Good luck.
Aug 01, 2011 | HP Compaq Presario SR1620NX...
The Cooling fan of my HP/Compaq Presario CQ60 sounds like a jet fighter! 2 questions 1) Replacement CPU cooling fan? 2) Can anybody give me pointers on how to get in to the laptop? I have tried blowing...
Presario CQ60 Repair Manual
From the above link from HP Official Support you can download the service/repair manual for instructions and photos for dis-assembly. Refer to "Fan/heat sink assembly" on page 4-41.
At page 4-7 onwards, you would find the instructions about opening the laptop.
INSTRUCTIONS & PHOTOS
Follow the instructions carefully and remove the Fan/ Heat Sink and Clean it using a tooth Brush.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 09, 2011 | HP Compaq Presario CQ60Z Notebook
I have a persario sr1620nx, the on board video went out, i need to install a video card, but i do not know what type to buy? looking for assistance. please help
Go to this website for specs.
http://reviews.cnet.com/desktops/hp-compaq-presario-sr1620nx/1707-3118_7-31589079.html
There's also an x16 PCI Express slot for users who want more graphics horsepower than the onboard ATI Radeon Xpress 200 chip affords.
Feb 08, 2011 | HP Compaq Presario SR1620NX...
Compaq Presario 3000 incredibly slow firing up, opening up anything. Loud fan all the time too
This advice relates to the Compaq Presario 3000 Notebook series but may also apply to other notebook computers as well.
The heat sink and fan assembly is probably clogged with dust and airborne particles. The clogged cooling parts can lead to heat problems with the CPU. When the system (CPU) gets to hot, the fan has to kick into high gear to try to cool things down. Once you remove dust and debre from the heat sink fins and fan, you will immediately experience better cooling and less fan usage. Your system may also be set for dynamic switching of CPU speed. If you CPU gets too hot, the system will reduce clock speed and ramp up fan and everything will slow way down. Use a good system monitoring software such as Notebook Hardware Control to monitor your CPU temperature, HDD temp and so forth. When the system starts getting too hot, first look at clogged heat sink fins as possible culprit. If you're good at electronics you may be able to service the unit yourself. Get a copy of the system's Maintenance and Service Manual or have a professional do the job for you as you will have to partially disassemble the computer to clean out the heat sink. Depending on the system, the job can take as little as 15-20 minutes once you become proficient at it.
May 09, 2009 | HP Laptop Keyboard for HP Compaq Presario...
Lines running along the screen which are permanent
may be the problem cause is heating...
may be cpu fan not working or there is heavy dust on fan..
try to clean cpu fan....
thanks
Mar 04, 2009 | Compaq Presario 2200 (292600-004) PC...
Compaq presario 6000 turns on but won't boot up.
Marj,
Dec 28, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
