Question about Dishwashers
Fisher paykel dishwasher
I am having a problem installing this dishwasher, can not seem to get it leveled and the top drawer is very hard to pull open and push closed
  • Dishwashers Master
  • 3,247 Answers
If this is a brand new dishwasher then you may need to get a qualified technician to install it to make sure you do not compromise the warranty.
If a second hand then it is likely the drawer seal is damaged. This could be rubbing on the dishwasher housing and not allowing to be shut properly.
Posted on May 05, 2013
  • 15 Answers
SOURCE: The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Posted on Apr 30, 2009
  • 3247 Answers
SOURCE: fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Posted on Dec 13, 2009
  • 30 Answers
SOURCE: My top drawer of my Fisher and Paykel dish washer
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Posted on Dec 21, 2009
Testimonial: "Thanks, that was exactly what was wrong, the one on the right was back and not catching the drawer, I flicked it forward and replaced the drawer, ta!!"
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
SOURCE: fisher paykel drawer dishwasher is stuck open and
Hey I dont know if you have this problem, but with mine the gasket seemed to be blocking the opening, so you could close it, but you had to shove a lot. The FP help line said to just unplug and replug in the unit. I did it and lo and behold it worked fine again. It did seem to leak a little bit the first time I reran it, but that seems to have gone away. Hope this helps
Posted on Dec 31, 2009
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
My Fisher Paykel dishwasher is flashing F1 - top drawer only. The bottom drawer is working just fine.
F1 error means the flood switch in the drawer is activated. If there is water inside when you open the drawer then you will have to manually empty it with a small container.
Most likely the solenoid that controls inlet water is faulty or the water level sensor is faulty.
Try turning the mains power and water off and on again and run dishwasher. If fault persists then you may have replace the parts.
Nov 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel top drawer stuck again
Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
May 15, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel Dishwasher Door Open error code
If it is a dish drawer type there is a clip at the rear of the drawer that holds the drawer closed. you will need to withdraw the drawer partially to look in. with the drawer open the fingers should be facing towards you. If not you will need to reach in and pull the top of the fingers towards the front. there is a replacement arm that holds the pipes and cables away from this part.
Nov 18, 2007 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
Owen Barnes
