Question about TENDA Computers & Internet
TENDA A3 150Mbps Wireless Range Extender is it a universal repeter . Ie mode bridde in order to repeat open wifi like frewifi
SOURCE: Linksys WRK54G versus WRT54G Firmware
Hi...
The WRK54G is actually a stripped down version of the WRT54G that was bundled with a wireless network adapter and sold under the kit name WKPC54G.
From what you say in your question I gather that you have a WRT54G already in place as your access point, and it is what is connected to your WAN. To use the WRK54G as a range extender repeater you should do the following:
1. Turn off DHCP
2. Turn off NAT
3. Assign a fixed IP that is in your Class C Block
4. Define the WRT54G as the Gateway
With this configuration it now should function as an extender/repeater, and any clients connecting to it will be serviced by the DHCP on the master router.
I hope that this helps.
Posted on Nov 15, 2007
  • 48 Answers
SOURCE: D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Posted on Feb 10, 2008
LaptopNomad
  • 12 Answers
SOURCE: Sitecom WL-130 Wireless Network Range Extender
For extending / repeating WIFI signals there's quite a bit of details to know about.
Read about repeating a WIFI signal with a sitecome WL-130 WIFI repeater here.
Posted on Oct 01, 2009
  • 153 Answers
SOURCE: Range Extender DWL-G710 & Wireless N Router DIR-615
Try to configure your new router and you have to reconfigure the Range extender to tally with the new router. The IP Address that the range extender should have should depend on the DHCP server of your router that provides the IP Address.
Posted on Jan 12, 2010
Testimonial: "Thanks, your advice made me start from the beginning - a very good place to start!"
SOURCE: Connecting D-Link DWL 3200 AP as a wireless extender to D-Link DSL-2640T
could you able to solve.pse share
Posted on Apr 03, 2010
Comcast changed my wireless password and now my netgear extender doe not work
You will need to reconfigure your extender, check the manual or online at the link bellow.
Since your extender is not working your range is diminished.
WiFi Range Extenders
Oct 18, 2015 | NetGear Universal WiFi Range Extender...
My Netgear WN3000RP Wi-Fi Range Extender is not working since last night . please help
Try unplugging BOTH the repeater and the router, Then, plug the router back in and let it establish a connection. Then, plug the repeater in and let it reestablish the connection.
Feb 03, 2015 | NetGear Universal WiFi Range Extender...
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
I ask to join and they ask for password and i typed in password and it will let me join
Try using the same security settings as your existing network by selecting the "Use the same security mode" check box when setting the your extender.
Jul 02, 2014 | NetGear Universal WiFi Range Extender...
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
I cant access the 192,168,2,1
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
How do I setup the Netgear WN3000RP Range Extender with a MAC
hello Friend
meathod is same eathyer its windows of mac . Just follow the same steps Ib both platforms.
Please Visit How to Setup Netgear Range Extender Mywifiext net And setup your Netgear range extender .
I hope this may help you setup your extender. Thanks
Dec 27, 2011 | NetGear Universal WiFi Range Extender...
Hi, I have a universal wifi range extender wn2000rpt installed and a wireless adapter installed aswell. Now reading the next set of instructions it tells me to connect to NETGEAR_EXT, open a browser and...
NETGEAR_EXT is the name or SSID of the extender. ie Netgear EXTender ;-]
What you need to do is first search for available wireless networks. It should show up there as NETGEAR_EXT if it is running and far enough away from your wifi.
Then open your web browser which should then open the connection wizard . If not you can try www.mywifiext.net. If you can't see it you may need to connect to it using a wire so you can set it up. sometimes if it is really messed up you may need to reset it to factory default.
Nov 11, 2010 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
Top TENDA Computers & Internet Experts
hellics
Level 1 Expert
Steve Sweetleaf
Steve Sweetleaf
John Walker
John Walker
Level 1 Expert
Are you a TENDA Computer and Internet Expert? Answer questions, earn points and help others
