Question about Pioneer Car Audio & Video
Can i bridge rear right and left to a single speaker of a single din car player directly wihout an amp?
  • 231 Answers
SOURCE: Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
Posted on Dec 24, 2007
  • 61 Answers
SOURCE: Kenwood KDC-X590 CD Player
what do you mean by one set is a hard wire and other is an rca jack?the hard wires go to the speakers and the rca is wired to an amplifier of some sort which is wired off to more speakers or subwoofer(s)
Posted on Aug 12, 2008
  • 4 Answers
SOURCE: Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Posted on Dec 09, 2008
  • 1348 Answers
SOURCE: proton jumbuck radio/cd removal & replacement with single DIN
take a flatblade and pry the panel that is clipped in around the radio.remove the 4 bolts holding in the radio.
Posted on May 23, 2009
rteemon
  • 578 Answers
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Posted on Jun 25, 2009
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
How do you replace the radio and insert a cd player?
Hi, pull the trim plate off the dash around the radio. The trim may go all around the instrument panel. With the trim plate off, you can see the factory radio screws. Take the screws out, pull the radio out and remove the connectors, including the antenna wire.
You will need an adapter to fit the aftermarket radio snugly into the dash. They sell these wherever they sell aftermarket radios. I recommend you also buy the cable adapter. If you don't, at least buy the antenna adapter of you will no be able to plug your antenna into the new CD player.
Follow the instructions on putting the adapter together--it's made for a lot of different cars. You need it to screw into your dash where the screws came out.
If you buy the wire adapter, follow the directions that come with it. I recommend you solder the wires, but you can use those crimp connectors if you don't have soldering equipment.
If you don't buy the adapter cable, use the factory wire colors below to match up the aftermarket wires to your factory wires. Wrap any solder connections with electrical tape and carefully plug everything back in, including the antenna adapter and antenna cable. With the adapter plate attached to the new player, carefully push the wiring aside to get the player into the slot and then screw it in. check the system for proper operation and then replace the trim panel.
Enjoy your CDs, and let me know if you have any questions.
2002 Chevrolet Silverado C1500 Radio Wiring Instructions
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2011 | 2002 Chevrolet Silverado 1500
I need help hooking my kicker cvr 12 to my direct 600 amp
Is the sub a single voice coil or dual???? If its a single, just bridge sub to amp....(+ of one channel and the - of the other) amp should show where to bridge with a diagram near speaker outs. If its a dual voice coil, then run one voice coil to the left channel and one voice coil to the right.
Nov 02, 2010 | Directed 600D Car Audio Amplifier
Can I connect the left front and rear together and same on right?
you can.. im guessing your trying to do that to "bridge" the amp to put out more watts.... you can do that but it puts a lot of strain on the amp that is pushing the speakers..(the radio)
Oct 18, 2009 | Pioneer TS-A6962R Car Speaker
It has an A and B channel for spkrs and i have one spkr bridged. do i split the neg to side a and pos to side b or just use one of the channels?
Could you elaborate on how the speaker is bridged?
I think you want to hook up a single speaker to a stereo speaker output.
In this case, you would strap (bridge?) the right and left speaker terminals by running a short wire from A right negative to A left negative. Then strap A right positive to A left positive -- this will give you mono output on either of the right or left speaker terminals -- connect your speaker to either one of these.
Do you know what the ohm rating is for the speaker outs on the amp and also the speaker itself?
Charlie
Aug 31, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Back rear speaker wont play when singled out. more details inside
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Help
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Feb 15, 2008 | Boss Riot 1500D Car Audio Amplifier
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Car Audio & Video Logo
59 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
