Question about Kenmore Dishwashers
Lower arm repair on Dishwasher?
We us the high temp "pots" setting. My dishwasher has been leaving a light gritty residue on the dishes. We have run cleaners a few times to no avail. Today I noticed the lower arm has a knob like a screw on top center and it looks broke. the lower unit wobbles. Everything seems to wash except as noted and the unit drains fine. Looking for some suggestions and is this something I can repair as a tradesmen but not an appliance repairman?
  • Bob Welborn May 05, 2013
    Thanks, it is a Kenmore Ultra Wash Model 665.1777990. Any information you might suggest would be appreciated.
  • Kenmore Master
  • 3,247 Answers
It will help if you can provide the model number of the kenmore dishwasher. I would try and take the wash arms out and clean them under running tap water. If the residue continues to appear then confirm if the problem is only with the bottom drawer or top drawer as well. Keep a couple of cups on the bottom shelf right side up and check the quality of water in these once dishwasher has drained at end of cycle. Also sometimes if the Rinse aid quantity is low it can lead to residue on glassware.
Posted on May 05, 2013
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
  • 126 Answers
SOURCE: Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Posted on Dec 13, 2007
  • 5 Answers
SOURCE: Viking Dishwasher leaves a film on the dishes
Hi! I found a great product at www.dishwasherfilter.com that will take care of this problem for you and your wife. It mounts under the sink and works great!
Use promo code DF5150 when ordering for an additional discount!
Posted on Apr 02, 2008
  • 677 Answers
SOURCE: Water not draining out after wash cycle
the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
jonniewalker
  • 1031 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
it could be due to Not filling enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
check the food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm.
. Remove torx screws that secure the sump cover. Remove primary filter. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
Posted on Aug 15, 2008
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
My fridgidaire dishwasher leaves gritty and oily residue on dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Oct 01, 2010 | Frigidaire Dishwasher Timer Assembly -...
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
My dishwasher leaves a cloudy residue on my dishes
The cloudy residue that is left on your dishes is soap that has not completly broken down.
There are a few solutions to the problem. First off, you want to ensure that you are using the "high temp wash" option. This will boost your water temp during the wash cycle to ensure that all the soap breaks down.
The second thing that you want to do to give your dishwasher a boost, is run the hot water in the sink and make sure it's pipping hot before you start your dishwasher. What this will do is ensure that the water that goes in for the "pre wash" portion of the wash is hot and will improve the wash quality.
Mar 01, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Fine gritty residue on dishes, particularly on glasses
alm84, Are you using a brand name powder like Electrosol or Cascade? Try that first. Seriously, it makes a difference.
When you say your water temp is within the recommended temp for the detergent manufacturer, do you mean the water heater temp at the sink tap is 120 degrees? MOST problems with cleaning that are not caused by generic detergent or plugged filter/debris in the impeller area are caused by a failed heating element. No kidding, it makes a BIG difference and once it is repaired, you will see an immediate difference.
glenda, First try this: remove the lower spray arm and the filter and assembly. Clean everything in the sink and with a flashlight, inspect everywhere for "chunks" that is probably causing the noise.
Reassemble and test. If dishes still do not get clean, check the heating element, replace if needed.
If that does not fix the problem, you will need to replace the main wash motor/impeller.
Good Luck!
Please update me with what you both find. OK?
Feb 25, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho I do not think the water is spraying from the...
Welcome to fixya,
You said, you have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho you do not think the water is spraying from the arms with adequate force.
I have the same machine.
And I notice if I leave the dishes in the sink rather than rinsing them off and putting them directly into the dishwasher, (Like My Wife says to do). That sometimes I have the same problem.
So I bought Jet Dry, and filled the holder. It's a small sometimes clear plastic knob that unscrews out above the soap dish.Fill it once a month!
Do you put the detergent in both cups or only the closed one?
1. If the load is not real dirty you should only have to fill the one with the door that closes.
If it is real dirty then both. To always use both is a waste of money!
2. If your hot water heater is far from your dishwasher, let the hot water tap run a minute till it comes out hot, before starting the dishwasher.
3.If the dishes or pans are very dirty and or baked on use hi temp scower and heavy or potscruber for those loads.
I use heavy wash and hot temp scower if the stuff is relly messy or dryed on.
And for baked on HI- temp scower and pot scruber which sprays harder.
You will have to experiment a little to see what works for you.
You will find it washeing good after you find what works for your families dish habits!
If you have any more questions let me know!!!
Please remember to leave me a solved before you leave the site.
Thank You for using us!
Huuum
Oct 02, 2008 | Dishwashers
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Mar 04, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
82 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
