Mitsubishi HS-U58 does not work
It does not accept tape. it spits it right out when I put it in
5 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Posted on Feb 28, 2008
  • 4234 Answers
SOURCE: Plays for 3 secs, stops, and then ejects
This unit needs to have the "idler" changed as well as the belts. Over time, the internal rubber parts get hard ans slippery. There are safety checks inside that will stop the unit when problems are detected. With a slipppery idler assembly, the tape does not get wound into the cassette after passing the heads. Rather than have the tape collect inside and be destroyed, the unit stops. This is a relatively simple repair that any shop should be able to perform. Expect a parts cost in the $35 range. In my opinion, this unit is worth the repair as it will continue to provide service to you for years to come. New replacement units tend to last only a year or two.
Dan
Posted on Dec 31, 2008
  • 9 Answers
SOURCE: when I put a tape in my vcr it spits it back out...
this sounds like a cleaning and tape carriage alignment is needed, that not too hard to do if you tinker.Service on this is not too much at electronic or tv repair
Posted on Jan 26, 2009
SOURCE: My Mitsubishi VCR HS-M60V rejects cassette tape
Take it to a technician
Posted on Aug 28, 2009
Mitsubishi HS-U775 S-VHS machine has no sound. Playback, rewind, FF, Pause functions work.
Get a VHS head cleaning tape from Walmart and try cleaning the players pickup heads.
Oct 17, 2016 | Mitsubishi HS-U775 S-VHS VCR
Mitsubishi hs m50v
I forget exactly how this goes but there are two posts on either side of the mechanism that read a light signal and a center pole that goes through the round hole on the cassette that gives the light signal (no tape-end of tape). Put a piece of tape on the two side posts and see if that changes anything. Be careful: the tape now knows where end of tape is - do not fast wind/rewind to the end! The loading motor may have failed or a rubber belt has slipped off or is too loose or broken.
Oct 20, 2013 | Mitsubishi HS-U445 VHS VCR
I put the tape in and it doesnt go in all the way, the machine rejects it and spits it out
The loading basket is bad, usually caused by a bad gear linkage, repairs will be pricey.
Apr 16, 2011 | Mitsubishi HS-U540 VHS VCR
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
Mitsubishi HS-U57 vcr front display gets very dim!
Your front display is worn out, it has gotten gassy. Therefore the luminance level is low & the part is no longer available.
Nov 07, 2009 | Mitsubishi HS-U577 VCR
When I put a tape in my vcr it spits it back out...
Jan 26, 2009 | Mitsubishi HS-U545 VHS VCR
Tape ejecting automatically
I found the spring on the tape carriage was off on one side. I reinstalled it and it fixed the problem
Dec 19, 2008 | Mitsubishi HS-U510 VHS VCR
Feb 28, 2008 | Mitsubishi HS-U447 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
