Question about Samsung Galaxy S Ii S2 I9100 16gb Unlocked Gsm Wi-fi Wifi Gps 8mp Android Phone
How to enter engineer mode - Samsung Galaxy S Ii S2 I9100 16gb Unlocked Gsm Wi-fi Wifi Gps 8mp Android Phone
98 Oldsmobile Aurora There's a on my Dash it says information center and has the oil fuel speed all that it says low oil is there any way anybody knows how to reset that
Check your engine oil using the oil dipstick located on the engine - you need to add oil to the fill line as shown on the dipstick. You should have the oil replaced regularly (every 3-6 months) and keep your eye on the level if the engine is leaking oil underneath or burning a lot of it.
Mar 08, 2017 | Oldsmobile Cars & Trucks
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    91 Subaru Legacy L+, 2.2 liter, mfi, no turbo, distributorless ignition. Check Engine light on, idles real rough (but runs fine at speed). I can't convince it to give me any flash codes. What is the...
    Read Memory Mode : used to pull codes which have been stored in memory. It is most effective in detecting poor contact of wiring harness connectors. To enter this mode, connect the read memory connector with the ignition ON . D Mode : used to diagnose and test the entire injection system. To enter this mode connect the test mode connector with the ignition ON . On the Legacy and SVX, the ignition must be ON with the engine running. F-Check Mode : used to measure the performance characteristics of the injection system components. When working in this mode, a Select Monitor or equivalent scan tool is required. U Check Mode : operates during normal engine operation. It signals the driver using the MIL only when components necessary for start-up and drive are faulty. The read memory and test connectors must be disconnected with the ignition ON for this mode to be operational.
    Jan 07, 2011 | 1991 Subaru Legacy
    I've lost the user code for a Ricoh Rex Rotary MP C3000 colour photocopier and can't use it. Does anyone know a master or engineer's code or smilar so I can get in and reset it?
    you enter service mode..and you search cancel the pasword.
    Entering and Exiting SP mode 1. Press the Clear Mode key.(reset button it should be yellow) 2. Use the keypad to enter “107”. 3. Hold down Clear/Stop for at least 3 seconds. 4. Enter the Service Mode.
    Jun 12, 2010 | Ricoh Office Equipment & Supplies
    When i type in a question on my TI-84 calculator the answer usually always ends with "e" HELP
    You're in Scientific or Engineering notation.
    Press the MODE button to enter the mode editor. Highlight "NORMAL" on the first line and press ENTER. Highlight "FLOAT" on the second line and press ENTER. Press 2ND QUIT to exit the mode editor.
    Mar 24, 2010 | Texas Instruments TI-84 Plus Calculator
    Oki C6100 Laser Printer drum reset - from Fatal
    1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
    2. Menu window will show "OKI USER"
    3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
    4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
    5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
    6. Window shows "NV-Ram- Initial Table 1".
    7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
    8. Restart printer.
    Feb 09, 2010 | OKI C6100n Laser Printer
    I MISTAKENLY ENTER THE ENGINEERING MODE AND PRESS THE HIGH SPEED SIM AND THE PHONE WENT OFF AND NOT COMING ON AGAIN. SCIPHONE I68+, CAN SOME ONE HELP BY PROVIDING HOW I CAN BRING THE PHONE ON AGAIN. THANKS
    Same issue , i was in the engineering mode . and pressed high speed sim and the phone blacked out ,
    Sciphone i9+++
    DOM :- 02/04/09
    TIME:- 16:28
    serial number :- 1234567890124
    Oct 26, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
    Reset drum life on oki c5500n
    try this:
    1) Power on printer while holding both the + & - buttons simultaneously; release when "Okiuser" is displayed.
    2) Press + or - until "Engine Diag" Mode is displayed; press Enter and Diagnostic Mode xx.xx.xx will be displayed
    3) Press and hold both Enter & On-line simultaneously until Eng Diag Level3 is displayed
    4) Press + or - until Local Parameter Set is displayed; release and press Enter
    5) Press + or - until it displays Factory Mode; if it displays Factory Mode Twice with an asterisk next to one then it is in Factory Mode; Press Enter, Press + or - until it displays Factory Mode & Shipping Mode on the display; then press and hold On-line & Cancel simultaneously; when it stops blinking an asterisk should be displayed next to Shipping Mode, which becomes the default mode.
    6) Power printer off then on to complete the procedure.
    Oct 12, 2009 | OKI C5500n Printer
    Sigmatel S4
    i have entered high speed sim option engineering mode in s4 sigmatel china mobile phone does not power on
    Aug 16, 2009 | Handmark Software MobileLists (950142) for...
    S 90 in flight mode
    Lots Of Time U Find That In S90 If U Select Flight Mode U Cant Press Menu Key To Change The Settings.
    No need to flash or format,
    Solution Is Just,
    Dial- *#3646633# in the home screen, u will see engineer mode select5th option 'Misc' then 6th option 'Assert Testing' now your phone willrestart, now u can able to enter menu go to settings & select 'Dualsim open' mode.
    no worries u don't even have to format the phone....
    Oct 09, 2008 | Handmark Software MobileLists (950142) for...
    Samsung Galaxy S Ii S2 I9100 16gb Unlocked Gsm Wi-fi Wifi Gps 8mp Android Phone Logo
    22 people viewed this question
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
