Question about Dell Dimension 2350 PC Desktop
I have a Dell 2350 PC and none of the usb or other ports work except the monitor
I just bought a used pc and when I plugged everything up and turned it on nothing works except the monitor. I cannot use the mouse or the keyboard and I tried using a keyboard that connects through usb and one that has a regular round plug and neither works. What should I do to regain the use of the pc? Again, I can not use a mouse or keyboard at all currently.
  • Dell Master
  • 27,725 Answers
Make sure the batteries are inserted correctly and have charge if applicable
usually located on the underside of the mouse there might be small plastic sticker with a phillips head screw under it rub your fingernail over the top to see if it has a screw
or make sure the usb device is properly inserted for wireless
the usb or Ps2 connection are secure with a dust free connection
or it might be the usb for wireless mouse or lead connecting to the usb port or even a faulty mouse
if this does not fix the problem
Restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
click start control panel administrative tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
Click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver rollback driver or uninstall also
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 arrows >> then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
http://www.microsoft.com/hardware/download/download.aspx?category=MK
complete range of drivers
Posted on May 05, 2013
muttuswami
  • 42 Answers
SOURCE: my usb ports aren't working at all
try reinstalling the chipset drivers from
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=27&impid=-1&servicetag=&SystemID=PLX_GX620&hidos=WW1&hidlang=en
Select the Operating system
The Category as Chipset
Importance should be All
Click on the Intel driver
Download now
File name is R132539.EXE
If this does not work you will be having 2 usb at the back and in the front of the system.IF the back does not work than you need to get a local tech out at your place as it is a problem with the USB controller on the motherboard and that might have to be replced .If it is the front USB (Only if you have them) then there is a cable coming from the USB controller to the fromnt usb ports that cable might have got unplugged for that you need to open the tower.But i would still recommend a local tech.
Posted on May 27, 2008
jeff_olymp24
  • 84 Answers
SOURCE: Problem with a dell computer..
You may try connecting a different usb keyboard to your system. Mostly, some keyboard converted from serial connection to a usb could cause this kind of problem. In some cases also, wireless keyboard and mouse won't work when u turned on your system if the driver is not properly install.
You may also try disconnecting any other usb devices from your computer. Disconnect also your power supply then push and hold the power button for 5 seconds. Plug back in the power cord then connect your keyboard. Turn on your computer. if it doesn't work, i suggest to call your computer manufacturer and check your warranty. This could be an issue with the motherboard of your computer.
Keep me posted.
Thanks.
Jeff
Posted on Oct 12, 2008
techniwiz
  • 275 Answers
SOURCE: dell 4600 usb ports not working
do one thing disconnect all the devices connected to the usb and if possible use a ps2 mouse to do the step i am going to tell you or if u can use the keyboard that would be fine ...
go to device manager and uninstall all that is under universal serial bus ... remove everything that says root hub and than restart the system
Posted on Oct 31, 2008
efs_perpends
  • 1996 Answers
SOURCE: none of my usb ports work. no mouse keyboard or
See this article. It may apply in your situation.
By uninstalling usb controllers and rebooting many of these errors are corrected...
Otherwise, perhaps this article will help you. I've found it useful. also here.
Also try here and enter your os to use the Dell usb troubleshooter for your system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 20, 2009
SOURCE: USB Keyboard and mouse wont work with PS2 KVM with adapter
Don't use USB-PS2 adapters if the keyboard/mouse doesn't support such adapters. They aren't universal, they work only with some "smart" (or chinese) keyboards that can detect the connection type and switch between USB and PS/2.
Posted on Nov 03, 2009
Dell dimension 2350 num lock wont turn off
I think it's the USB port problem.. try unplugging the keyboard plug and plug it to another port.. and you can also try restarting your computer.. if problem still occur, your keyboard probably malfunctioned
Dec 13, 2013 | Dell Dimension 2350 PC Desktop
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
I have no sound on my dell dimension 2350 the drivers from dell didnt work and i have TRIED EVERYTHING I KNOW TO TRY Help me Plz
Be certain that you have your speakers plugged into the correct port, and that they are turned on.
Oct 03, 2010 | Dell Dimension 2350 PC Desktop
Trying to hook up dell 2350 computer to hdtv can i use the serial port in any way to be able to have two monitors working at the same time
No, you should get VGA Card/ Graphics Card that support HDTV.
Plug it on the PCI Slot, then you're able to enjoy it..........
Oct 23, 2009 | Dell Dimension 2350 PC Desktop
I need the usb controller driver for the dell dimension 2350 know where i can find it? thanks
The USB controller driver for Windows XP is a Native XP driver. If you have a problem with it, boot to the safe mode, go to device manager, remove the controller from list, make sure all USB devices are disconnected (Keyboard and Mouse excepted) reboot and let the controller re-detect.
If that doesn't work, then try a repair install of XP
Oct 21, 2009 | Dell Dimension 2350 PC Desktop
When I Boot up it Dosent display the screen Any
What you've plug ?
if what you mean is a socket monitor to VGA port,
i think you have a problem with your monitor.
try to use another monitor if U have one.
boot up doesn't display ?
go into BIOS setup,look for "load BIOS SetUp Default or Load For Best Performance".
Choose it,Save and Exit.
Sep 25, 2009 | Dell Dimension 2350 PC Desktop
Ports not working
you press the reset button from the pc by the time you restart it everything will be working properly
Jun 02, 2008 | Dell Dimension 2400 PC Desktop
Side USB ports
You need to connect a USB cable from your PC to the USB port under the monitor.
It is a standard usb cable used by printers with a flat plug on one end and a squareish plug on the other.
You should also have 2 more usb ports under the screen as well. There are normally 4 on Dell screens. 2 side, 2 under, and the one square plug to connect to the PC.
Feb 20, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell Dimension 2350 PC Desktop Logo
50 people viewed this question
Alun Cox
