Question about Boating
Evinrude approx 1973 wont stay started when put into gear
The engine will start however dies when put into gear either forward or reverse
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 63 Answers
You have carb issues, you can try seafoam or better yet they need to cleaned.
Posted on May 05, 2013
  • 6 Answers
SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Posted on Aug 22, 2009
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
  • 51526 Answers
SOURCE: How do i remove the forward gear and pinion from
there is a large snap ring inside the case to remove first . best left to a service shop .even tho they cost too much .
Posted on Apr 25, 2010
  • 51526 Answers
SOURCE: 1981 15 HP GAMEFISHER WONT SHIFT IN TO FORWARD POSITION
shift rod linkage is wrong .
Posted on Apr 26, 2010
  • 677 Answers
SOURCE: Gear shifter locked in forward gear
If the gear lever is loose,it's the gear connection rod that you disconnect to do a g/box drop.If its not loose, drop the g/box off the leg and the first thing you find might be the problem.A loose bolt,a jammed shifter.It will probably be a connection problem than a g/box problemHope this helps
Posted on Jun 24, 2010
agent91
  • 2100 Answers
SOURCE: motor top filled with water and died. what
It shouldn't cause any problems , once it dries out, it should fire back up and run, get the water out of the carbs if you can, or make sure there is no water in there, where did the water come from? You might have to prime the pistons with fresh gas to get it to fire, make sure the plugs are dry and clean. We had a honda pump on a barge and it went in the river, we grabbed the hose and pulled it back up, fired right up and ran fine all day. What an engine. Hope this helps.
Posted on Jul 18, 2010
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Car will start but put it in gear engine will die
engine starts with no problem; but, when I put in gear and ...
www.cargurus.com > Questions > Hyundai > Sonata
CarGurusNov 15, 2012 - The engine just fall dead when you step on the gas; it seems to jerk before ... My car does the same thing but i put it in neutral n it starts up. ... I have a 2004 kia optima it jerks when I go into reverse it was driving ... start and run fine butwhen I put it in drive or any other gear it dies! ... 2002 Hyundai Elantra GT.
Engine stalls when tranny put in Drive or Reverse - Kia Forum
www.kia-forums.com/kia-carnival...2002.../43407-engine-stalls-when-tr...
Feb 28, 2008 - 10 posts - ‎3 authors
Give it a little gas before putting in D or R and it will go. .... When I start the van cold and shift the tranny into drive or reverse.....the whole front ... won't run in forward gears - Kia Forum
May 25, 2012
Intriguing problem - engine rough idle & hesitation ...
Aug 31, 2011
2006 Kia Spectra engine stalls and bad idle, cleaning the ...
Aug 30, 2010
2002 Kia Spectra Won't Go Out of Park - Kia Forum
Oct 28, 2008
More results from www.kia-forums.com
Dec 17, 2015 | 2002 Kia Rio
My 1973 Johnson 40hp boat motor will not shift in forward, Only reverse
Try searching our boating forum for answers to your Johnson motor problems. Johnson Evinrude Outboards
Apr 02, 2014 | Boating
Dies when put in gear and does not start
you must test the Alternator. see the diagrams attached.
God bless you
be25bf83-7851-4c69-a5cf-df8f11af48d2.jpga4a3f2a2-fd87-4d18-973a-a6862e966170.jpg4bc5cc5e-d718-4029-9e58-8091b32b27ea.jpg
Jul 27, 2013 | Pontiac Firebird Cars & Trucks
1993 Bronco 5.8L, dies in reverse, and in low forward
not sure on your year but check the modulator on the transmission. remove the vacuum line at the modulator and see if there is any tranny fluid there. if the there is change the modulator.
Jan 15, 2010 | 1993 Ford Bronco
Aug 22, 2009 | Boating
Volvo xc70--engine starts but truck doesn't move when put in gear
check tranny fluid.if fluid level is correct.change fluid and filter if its been a long while.if it still wont go into gear.your tranny oil pump is worn.and the forward clutch seals and drive plates worn.
Jun 11, 2009 | 1998 Volvo S70
1996 evinrude outboard stalls when put in gear idles good in neutral & runs out good in gear but stalls idling in gear
Start by adjusting your idle mixture screw. Start at 1 1/2 turns out and with the engine in gear at an idle slowly turn the screw clockwise until the engine starts to die, then back off a half turn and that will be your proper setting. If you need to you can bump up your idle stop screw just a touch so it will hold also.
Mar 23, 2009 | Boating
Boating Logo
109 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
