Question about Pioneer Car Audio & Video
DEH-15UB I bought a radio from pioneer but it only turns on when my lights are on like at night or in early morning and i have and 2000 Oldsmobile
  • 54 Answers
Hi brian, the remedy to your problem is simple. your power wiring from the unit has been incorrectly connected to the vehicle. from the unit connect the yellow wire "directly" to the battery +12v positive line, and the red wire to a "swiched" +12v positive position on the ignition barrel, OR the yellow and red wires can be joined together directly on the battery +12v positive line. also make sure that the ground connection is 100% secure. cheers.
Posted on May 05, 2013
  •  TE5LA
    TE5LA Dec 29, 2013
    If a proper adapter harness was used, there should be either an orange or orange/white wire that is probably connected to the radio's red or yellow wires. Remove it and connect red to red and yellow to yellow. Cap off the orange wires.
5 Suggested Answers
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
shawnsz
  • 64 Answers
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Posted on Feb 18, 2009
  • 87 Answers
SOURCE: wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Posted on Jun 02, 2009
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
I need to know the pinout configuration on a pioneer DEH-15UB
I assume you do not have the harness? I would suggest buying one they are available on ebay, amazon, metraonline.com plus dozens more sources. Connecting wires to the pins on the radio chassis is difficult at best and all it would take is one to touch the wrong one and fry the radio.
Aug 09, 2016 | Pioneer Car Audio & Video
Controlling my iPod.
This model radio is not iPad compatible. All pioneer radios display on the box whether or not they have iPod or Android capabilities. It notices your iPod because of the data and power connection it emits when it's plugged in.
http://foraudiogeeks.com/
Apr 16, 2016 | Pioneer Car Audio & Video
Amp error message on Pioneer DEH-15UB. Vehicle was jump started twice would this cause this problem? The receiver is not connected to an external amp. The radio/cd player will work for about two minutes...
I just had an "amp error" message display on my Pioneer DEH-15UB and it quit playing. No sound at all. It happened while I was driving my Jeep. When I got home I removed the passenger side speaker from the sound bar and found the previous owner had used a wood screw to hold the wire to the speaker. That screw came into contact with the metal roll bar and caused the error. When I installed ends on the wires the error message cleared itself and now works fine
Sep 17, 2013 | Car Audio & Video
Pioneer deh-15ub usb port will not play iphone
Pioneer deh 15 ub does not have intial setup option and my music plays bass and hardly and vocals at a low state.I need it to say rear rear
Dec 23, 2012 | Car Audio & Video
I need to know wiring diagram for a pioneer deh-15ub cd rds receiver.
The deh 15ub doesn't have the orange wire at least mine didn't other then that its the same as above.
Oct 15, 2012 | Car Audio & Video
Left the radio on all night and the battery died. When I started the car with jumper cables the radio will not turn back on....Model DEH-P3000IB please advise
Leaving the radio on all night probably would not completly drain the battery if it is in good shape. You need an unlock code for the radio. Refer to the owners manual or down load a manual form Pioneer Electronics.
Sep 24, 2009 | Pioneer Car Audio & Video
After reconnecting the car battery, the radio would not turn on
The pioneer has a small protection fuse in the back of the radio, alot of time when it catches a power spike, it will blow to protect the head unit. It should be plugged in the back of the radio under the main plug. Hope this helps.
Aug 20, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Installing my deh 2300
Heres all the radio wiring colors for your car:
Jun 02, 2009 | Pioneer DEH-2300 CD Player
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Car Audio & Video Logo
620 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
