Question about Garden
My Simplicity Broadmoor Hydro 14, won't engage
3 Suggested Answers
  • 2239 Answers
SOURCE: blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Posted on Jun 24, 2012
.Lubrication
Posted on Jul 14, 2013
My simplicity riding lawn mower was submerged for about a half hour and will not start. what should I do?
change the sump oil , remove the plug and dry off, turn motor over with out the plug to empty water from the cylinder
remove fuel tank and empty water out , remove carby and empty water out
check all switches for water immersion
Jul 24, 2016 | Simplicity Broadmoor 20hp Briggs &...
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Riding mower won't go nowhere it's got drive belt on but won't drive
Is it a hydro? check the release lever some times i forget too. If its gears then try different gear and check that the belt is engaging fully if the clutch spring broke your pedal shouldn't push back up.
Oct 03, 2012 | Craftsman Garden
I need a wiring diagram for a 1968 simplicity 717 broadmoor
Well the digram is not available saperately you have to buy the service manual for this digram. If you want to buy it from net then please visit the link below -
http://www.themanualsworx.com/simplicity%20broadmoor%20717%201968%20chassis%20onlysvc%20service%20svc%20manual-p-15204.html
It's available for $57.59 USD.
Regards
May 29, 2012 | Garden
Mower starts but drives very slow or not at all, but fine in reverse.
If this is a hydro unit and it drives fine in reverse then there is no reason why it will not do the same in forward, there is a variable swash plate in the unit to change from reverse to forward, i would be looking at the linkages, if there is not enough movement it will greatly affect speed, check also that the pulley on top of the hydro is tigh and has not stripped the splines.
Apr 14, 2012 | Garden
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
