Question about Swiss Military Hanowa Mens Navalus Chrono Black Dial Wrist Watch 06-4149-04-007
Watch strap I can't find a replacement strap for Swiss Military hanowa Navalus Cronos
Hi, I have bought a swiss watch hanowa and when i opened the box, i found out it is not working. Do i haave to set something up before it starts or is it a problem with the watch?
battery operated watches have a small plastic tag under the crown
this prevents the battery making contact so it does not go flat in storage
pull that tag out and press the knob home and it will start operating
Mar 13, 2017 | Swiss Watches
Can you help me set my surface watch model 33009
Are you sure the number 33009 is correct?
Most Wenger watches have 5-digit numbers starting with 7.
There is a Swiss Military Manual here:
https://www.wengerna.com/stuff/contentmgr/files/6/540159dc9885eeee1a65eec748ed4597/pdf/swiss_military_watch_manual_2012.pdf
May 07, 2014 | Wenger Swiss Military Classic Field Watch...
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
Wenger Swiss Military Watches Sportedge Bracelet Watch (For Women): I've dropped my watch on the ground twice at work ...
Please run through below link. That is the site of Swiss, and Customer Services will help you, depending from what country you came from.
Swiss
May 17, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
Wenger Swiss Military Watch: small set-time handle fell off.
That small gizmo is called CROWN or WINDING CROWN. It is not possible to obtain it online, so, you have to shop around for it. Find your nearest watchmakers shop and ask for replacement. You may need stem as well.
Rate, please.
Jul 09, 2009 | Watches
Connect metal strap to watch
If it brok at the hinge where the strap connects to the watch itself, then you might just need to replace the clip that slides in. Its a little metal tube with a spring in it. You should be able to find them at any retail shop. If all else fails, take it to a shop or jeweler.
Mar 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Swiss Military Hanowa Mens Navalus Chrono Black Dial Wrist Watch 06-4149-04-007 Logo
44 people viewed this question
Top Swiss Military Watches Experts
Jimmy Accardi
Are you a Swiss Military Watch Expert? Answer questions, earn points and help others
