Question about American Standard Hampton Two-Handle Bath/Shower Faucet ...
Sunken bathtub The tub is sunken with safety's handles niched inside the tub near the top on both sides.
  • American Sta... Master
  • 16,648 Answers
Is there are question in this somewhere?
Posted on May 19, 2013
C key is sunken down. The hammer action counterbalance isn't working properly
Check it again. It may have something dragging on the key, maybe something sticky like soda or juice residue. You can also try swapping out the key with another C or F key that is less used. Good luck!
Sep 24, 2016 | Casio Privia PX150 Digital Piano
Why does it leak on right side?
Hello. I need the model number to help you accurately but initially, you need to remove the kick panel below the door and identify the leak if possible. Use a flashlight and look for the telltale residue trails or wet spots. There could be a loose clamp, pinhole in a drain line, or a hole in the hose connecting the main pump. A lot of dishwashers have a leak sensor that trips if water is present and shuts down the unit. It is usually located at the center of a sunken base so that any leakage dribbles straight to the sensor. A lot of models have the drain pump located near the front, it could be on the left or right side. Also, if your unit has a float switch(flying saucer shaped object near the front of the tub, inside), the seal for the switch might have developed a leak. I've seen the large plastic retaining nut become loose due to the constant heating/cooling inherent in the operation of dishwashers. The float can be gently/firmly removed by pulling up on it. This exposes the nut and it usually has a rubber seal beneath it. When no water is in the tub, the float is at rest and pushes a tiny micro-switch beneath the tub which signals the main board that there is no water. When the proper water level is reached, the float releases the switch signaling the main board to shut off water and start the cleaning cycle you chose. Now, the water also could be coming from another area totally unrelated--water follows the path of least resistance and the smallest un-level or lower area will direct any water. I hope I helped you!
Sep 13, 2015 | Kenmore Dishwashers
Jambox
The same thing it's happened when my jam box won't turn off because the Power Button has sunken in!? Someone help!
Aug 28, 2014 | Jawbone Big Jambox Portable Bluetooth...
Wash tub off center, tilted
it is possible for these machines to come off their springs when being moved or going badly out of balance. you will need to lift the bowl with one hand on the side it is sunken, and use the other to re position the rod / spring into the slot on the side of the bowl. they can also sit up on their springs, which just requires a quick jolt with your weight on the side that is raised, it will click back down.
Sep 25, 2013 | Fisher and Paykel GWL11 Top Load Washer
How to remove chainsaw muffler
If this is the Husqvarna 440, there are two allen headed screws sunken down inside the holes in the front of the muffler, its either a 5mm or 6mm long arm allen key required.
Jun 16, 2013 | Husqvarna Chainsaw 440E-18
Locate fuel door opener
DId you happen to receive an answer yet? On most Suzuki's and Mitsubishis, the fuel door release is directly under drivers seat on the left side. THe SUzuki's is a flat flap type "lift" button thats sunken into the molding trim around bottom of seat. Makes it hard to find. Mitsubishi models, if its in same place, will have a fuel hose symbol on top of the lift up latch, even though it doesnt look like a button or lift up release.
Hope this helps
Jun 03, 2012 | 2011 Mitsubishi Galant
How to replace power button on fujitsu p8010
to get to it you have to remove the front part of the keyboard ..and the keyboard itself... take a look at this video
http://www.youtube.com/watch?v=hzmkUjDxbBs
after that the lower part will get out too ..if needed ..I mean the part with the pad ....the order of disablement is the same in most laptops...
start with he part that covers the hinges ...
and always expend the display to maximum possible...for easy access
Apr 17, 2010 | Fujitsu LifeBook P8010 NoteBook Intel Core...
Mpv spare location
Check your manual. it is on the passenger's side just below the middle seats under the floor. I believe there is a bolt that has to be undone from the inside of the van to lower the spare. It is not at the back like most vans because of the sunken trunk.
Apr 03, 2010 | 2000 Mazda MPV
American Standard Hampton Two-Handle Bath/Shower Faucet ... Logo
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
