Question about Magellan RoadMate 700 GPS Receiver
Negative audio test
I don't have turn by turn audio.
    Novelist:
    Scholar:
  • 86 Answers
Traveller... Do you hear ANY sounds at all from the unit. how about when you scroll the volume knob + & -? is it a faint sound? can you barely hear it? hold it close.. (make sure it's clean though) oh yea.. and this is all at your own risk.. :) audio cut out could be caused by: 1. A metallic object stuck to the back of the speaker. You would be surprised what gets in there. 2. Speaker wire solder parted, either side. 3. Sometimes a simple clearing of the user data will work. A) At user menu press "-" key, "+" zoom in key and press the repeat button on the top all at the same time. B) At the secret" " menu, select clear user data. Unit will automatically reset. 4. The speaker connections themselves could be loose or melted. If I was working on your unit, I would first make sure all the connections are clean and sturdy. if no joy, I'd swap out the speaker to check to see if it's a bad speaker. If this wasn't the problem, I would reload the software. If no, I would swap out the I/O board and test for power issues.
Posted on Sep 22, 2007
Not exactly true. Last spring I lost audio in my 700 while driving. Restarting it did not help. Contacting Magellan I was told first they were NOT supporting the 700 any longer and that the only thing I could do was trade it in for $100 for a newer model. I wrote a letter to the President of Magellan expressing my disappointment with such support considering I paid over $1200 when I bought it brand new 2.5 years ago. As a result, I got a call later from the Magellan repair in Texas and was told that since my unit was out of warranty they would repair my audio problem for a flat fee of $150.95, NOT $49.95. Well, I sent it in with a fee in April, 2007. Guess what? The audio stopped working once again in August. I am out of luck and my money, since the warranty on the repair was only 30 days. Isn't this something? NO MORE MAGELLAN BRAND FOR ME, that's for sure.
Posted on Sep 09, 2007
Hi Please use the Audio test.If still its not working then send the unit for service.Magellan will charge you $ 49.95 if its not in warranty.
Posted on Aug 19, 2007
SOURCE:
Jvc car stereo KD-R570 flashing red
To test radio to see if its working you can bench test it. This means to combine red and yellow and run to 12V positive and Black to 12V negative. IF radio turns on, it would mean its working.
Aug 04, 2014 | JVC Car Audio & Video
08 Mondeo,6000CD Audio Unit has been turning on when car is locked.
maybe its possible that you could have mixed the the power lock trigger with the remote wire. undo setup and grab a test light and test all your wires especially the power and ground wires. Also test all the wires while clicking the clicker, so you see if anything there's a positive or negative trigger setting it off. Let me know how everything turns out.
Mar 12, 2013 | Cars & Trucks
Which wire is positive and negative
Red is positive and black is negative that is industry standard, but if the wires don't follow that code you need a digital meter, set on DC volts to identify.
Apr 18, 2012 | Aiwa Audio Players & Recorders
My 1997 Chevy Lumina will not turn on. I thought it was the starter since it started having difficulties turning on. The security light on the dash is permanently on. So i replaced the starter and tested...
REPLACE BATTERY CABLES THE POSITIVE BATTERY CABLE COULD BE SHORTING TO GROUND.REPLACE STARTER SOLENOID IF NOT BEEN REPLACED.BESURE TO PLACE BACK FLEXIBLE CONDUIT THAT GOES AROUND POSITIVE BATTERY KEEP FROM SHORTING TO GROUND. LAST TIME I SEEN BATTERY CABLES OVER HEAT WAS EITHER STARTER AND SOLENOID SHORTING OUT OR VERY LOOSE BATTERY CABLES CONNECTIONS. REPLACE BATTERY CABLES IF THEY ARE MELTED HAVE STARTER CHECKED OUT YOU COULD HAVE FAULTY STARTER STILL.
Sep 06, 2011 | 1997 Chevrolet Lumina
We have a DEH-6 pioneer radio that we are trying to install in the 1994 dodge caravan.We cannot find where to hook the white wire from the radio. when you turn the ignition on the radio lights up but the...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
May 29, 2011 | Pioneer DEH-P690UB CD Player
Stereo wiring harness need to the colors and what they do? for a 1997 mercury mountaineer
cannot find 97 but found 98. Do these match?
1998 Mercury Mountaineer Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6? x 8?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: 6? x 8?
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1997 Mercury Mountaineer
I have a Ford F-150 1990 Model. It doesn't seem to be getting fire to the sparkplugs. I just replaced the spark plug wires and spark plugs. What could be the problem? It is a V8.
Sounds like its a distributor. To test if its sparking at all take the plug wire and hold a screw driver and see if it arcs to the screw driver when you crank it. but heres the best way to diagnose it on your vehicle follow the following steps and let me know from there what happens.
Steps
1 Remove the spark plug wires one at a time and insert a small screw driver into the wire.(SEE WARNINGS) Be careful as you don’t want to get shocked with 60,000volts. Hold the wire so that the screw driver is 1/8” away from the engine. Have someone crank the engine and watch for a good white spark. If you have a good spark on all wires look for a problem with timing or something else. 2 Remove the distributor cap. Have someone crank the engine over with the distributor cap removed and observe if it is turning? That is if it has a distributor cap, some newer cars don’t have one. If the distributor is not turning then likely you have a broken timing belt or chain. 3 Turn the ignition key on but don't crank the engine. Locate the positive or power wire attached to the engine coil. Using a test light check for power. If this has power, then the wiring from the ignition switch is OK. 4 Locate the negative or ground wire attached to the engine coil. Using a test light check for power. This sounds strange however, one end on a good battery ground and the other on the negative wire attached to the engine coil. The test light will light up indicating power on the negative side of the coil with the key on and engine off. 5 Have someone crank the engine while watching the test light. If you observe the test light flickering when cranking the engine and you have no spark, either the coil wire is faulty of the coil is dead. Test these using an Ohm meter.# If no flickering or pulsating was observed then check continuity in all primary circuit wiring for opens. This is the negative wire back to it's source, the ignition module. 6 Check the pulse generator in the distributor if it has a distributor cap. Some newer cars don’t have one,and if it doesn’t then the ECM or computer sends signal via the crankshaft position sensor and the camshaft position sensor. 7 With the engine in non-running condition connect your A/C voltmeter to the pair of wires at the pulse generator and crank the engine. You are looking for an A/C signal that makes 4-6 volts of A/C. If this is observed then the ignition module is dead or has a bad ground. If no A/C signal is observed then you have a dead pulse generator in the distributor. 8 Know that if this part of the primary ignition tests OK then check wiring to ECM pinouts for opens. If wiring tests are OK. Suspect the ECM or computer as a last resort. edit
Warnings
Be careful as you don’t want to get shocked with 60,000volts. be careful when checking the leads for sparks with a screwdriver doing it this way can cause very expensive damage on newer engins best use a spare spark plug or a proper tester for this job
Thanks, Midwest-tek
Aug 30, 2010 | 1990 Ford F150
Cant install aftermarket stereo
The Wht/Blue wire is allways 12 volts; The Ylw/Red is switched only when the car key is on accessories.
1994 Isuzu Amigo Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: White/Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Illumination Wire: Blue/White
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Jan 04, 2010 | Car Audio & Video
My amp is not turning on.
check power from battery
ground
and remote
if you have power from battery then either your ground or remote power is not working
Apr 03, 2009 | Sony XM-1502SX Car Audio Amplifier
1996 chevy 1500
with the ignition in the "off" position get a test light and touch one wire at a time while cycling the ignition switch to the "on" position, When you see that the test light goes off when the ignition switch is in the off position then you found the hot wire, make sure you dont hook it up to the "alway hot " wire or you might drain the battery hope this helps.
Oct 18, 2008 | 1996 Chevrolet Express
Magellan RoadMate 700 GPS Receiver Logo
82 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
