Question about Mitsubishi VS-50111 50" Rear Projection Television
Restore factory settings on VS-50111
There is no reset button, I am trying to reset factory settings on mitsubishi tv vs-50111 without the original remote. VCHIP is locked and I can't reset as I don't have the password. Nice TV received from friend, but can't watch a lot of shows with the VCHIP locked, would hate to send to curb, but hubby is giving me a week?!!! HELP!!!
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
SOURCE: Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Posted on Mar 06, 2008
SOURCE: mitsubishi VS-5041
SO I reprogram the dish network remote control? Can you get the codes off the net?
Thanks
Posted on Apr 04, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV Code
you can get the actual remote for that model at www.replacementremotes.com just enter the model number. You may need the service manual to actually erase that code.
Posted on Apr 09, 2008
  • 4090 Answers
SOURCE: picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Posted on Nov 30, 2009
I locked the front button on me 50 inch tv its a mitsubishi 1080 hd series and dont have the remote i do i reset the thing
the only way to reset this thing is to bring new remote for this model & unlock with it. get the original remote from authorized service station.
Aug 19, 2011 | Mitsubishi VS-50111 50" Rear Projection...
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
VS-50111 and horizontal lines appear and shuts off
hello i have the service manual which i'll send for free along as you leave me a fair rating thanks
regards
shaun
May 31, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Picture on the mitsubishi HD1080 VS-50111
Nov 30, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Where are the fuses for mitsubishi 50111 located and what do they look like?
There is only one user serviceable fuse on the TV set on the PC board, near where the power cored enters the TV (you will need to remove the back to check this fuse (it is labeled F9D00).
The other five fuses look like small resistors and will require desoldering to replace -- I wouldn't recommend doing this without testing the fuses with a Ohmeter first, to determine if they are bad.
Jun 29, 2009 | Mitsubishi VS-50111 50" Rear Projection...
2002 Mitsubishi VS-50111 WIll Not Stay on
FIRST Check for open fuses F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF fuses are open then convergence output circuit would be your problem.
Dec 17, 2007 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi va-50111 television
You have to hold the menu button for about 8 seconds. You'll get a sign at the bottom of the screen that says "Front Panel Lock Disabled"
May 04, 2006 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
