Question about Baby Gear
Okla homer smith crib
We have model 80558 in the crib given to us but the screw holes in the bottom of the crib legs are to big for the screws did they have an insert that i don't have perhaps
3 Suggested Answers
  • 16 Answers
SOURCE: instructions for Okla. Homer Smith Furniture crib
Call this number is can help.call 1-800-OHS-Furn
Posted on Oct 03, 2010
SOURCE: I need instructions for Okla
I will advice you check manualsonline.com to search for the instruction manual of your device.
Take care.
Posted on Oct 17, 2010
Need the hooks and bolts for little angels swinging crib
Sorry, best I can tell you is to hold the pieces together and measure the holes both diameter and length. Then go to either your big box or local hardware store and buy the screws and nuts and washers. Of course the screws need to be longer than the holes and purchase Stop nuts (nyloc nuts) so they don't come loose by themselves.
Nov 08, 2016 | Baby Gear
I was given a Nod-a-Way crib (I think Cosco is the manufacturer) that's approx. 20 years old and two of the brackets attaching the metal spring to the frame of the crib are missing. Can't seem to...
I have a nod a way and just gave it to a friend the style was Okla Homer Smith and the manufacter was Dorel Juvenile. My bed was made in 97, Jenny lind style hope this helps.
Sep 06, 2011 | Evenflo Jenny Lind Crib
I have a crib that was manufactured by "OKLA HOMER
And what seems to be the problem ?
Sep 11, 2017 | Baby Gear
Lowering the mattress
I have the same issue... can anyone let us know if you have managed to put the mattress on the lowest (4th hole) setting? PLEASE.
Jul 28, 2010 | DaVinci Emily Crib
Missing screws
Go to a Westlake or Ace hardware.
they have a huge selection of screws.
the ones you want are metric/machine screws.
11/2" and 3/4", get some washers to go with.
Jun 29, 2010 | Simplicity for Children Aspen 4-in-1...
Need new screws
Just a suggestion, the way I'd do it is to get a screw that isn't missing, go to either Lowes or Home Depot and see if they can get you a screw that is the closest match.
If you have no screws, measure the hole for the screw in the crib. Take a pencil, skewer, or anything thin and mark the depth of the hole to determine how long of a screw you need; and also the width of the hole itself. Again, at either store, find the screw that best fits. Since it is a crib and you do want it to be sturdy, go for a thick screw. It's ok if its just a tiny bit wider because then it will grip better. Be careful not to get it too big as it could crack the wood.
Good luck and please rate my solution accordingly.
V/r,
Don
Jan 30, 2010 | Kinderkraft Vermont Crib
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
How to convert crib to bed
I have the opposite problem - I can put it together as a toddler bed. The trick with that is that you put one of the long screws through both the hole at the SHORT end of the toddler bed side AND the metal flange from the springs into that end of the crib. The other long screw goes through the raised end of the toddler side into the end of the crib - where the child's head would be.
Is there supposed to be a plastic piece at the top of both ends of the crib on the side that does NOT go up and down? I can't seem to figure out how to put the crib side on.
Nov 03, 2007 | Childesigns Bellmont Crib
Missing crib screws
Screw can be purchased from amazon, click here and take a look: Amazon com crib screws. I hope this was helpful. Cheers
Oct 20, 2007 | Delta Enterprise Versailles 4970 Crib
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
