Question about Velodyne DLS-3750 Subwoofer
Subwoofer inop i had a problem with a cicuit in the house that was arcing in the electrical turning the power off and on to my entertainment system. Since then my subwoofer has been inoperative. It will not turn on with the amp any longer and no sound. I found the remote and the blue power indicator light comes on but will not remain on and no sound. I disconnect or disconnect the input from the amp and it has a loud buzz or hum only.
    Top Expert:
  • Velodyne Master
  • 35,531 Answers
The blue power light merely indicates that house power is getting to the sub. My guess is that the internal power supply reacted poorly to the on-again-off-again power application and something failed
Posted on May 04, 2013
4 Suggested Answers
xMadx
  • 64 Answers
SOURCE: Major buzz/Humming sound coming from my subwoofer
Well there are only a few reasons i can think of that just might be the reason behind said buzzing.
1. It may be connected to another power source ( amplified or powered supply ) or incorrectly connected. It may also be too close to said power supply.Try letting the dog (sub) out on his leash a little Drag out the manual that came with the sub, and check the correct procedure for your type of setup.
**People do read manuals still don't they ?**
2.The only other problem i have heard of is port noise in low registers. Keep the the port area clean, as it may suck up dirt, or even worse, small children!
3. However, if you're considering placing this subwoofer in a cabinet, I'd recommend allowing ample breathing room for the heat sink. This can also be done by drilling smaller holes in the cabinet ( 8-12 mm holes - with the owners permission of course) but please do remember to keep the port area clean.
4. The product ie: Velodyne DPS-12 Subwoofer, came with a bad power supply, presuming it is new, check your warranty.
(not very likely - see also scenarios 1, 2 or 3.)
Velodyne has been making subs forever and do it well.
Posted on Jan 17, 2008
  • 124 Answers
SOURCE: loud hum when HGS 10 is turned on
Bad amp
Contact Velodyne
Posted on Dec 20, 2009
  • 124 Answers
SOURCE: I have connected the subwoofer to the pre-amp out
One of two things may be going on.
The amp has a fuse mounted on the PC board. The fuse may be blown.
The speaker may be bad. that may have blown the fuse.
You can test the speaker with a "D" battery.
Take the amp section out of the back, disconnect the speaker leads.
Touch the speaker leads to the poles of the battery. it should make a little thump and the cone should move freely.
Contact Velodyne for service.
Posted on Dec 30, 2009
Blew fuse bose 321
When a fuse turn black, you have a serious short inside. Repalcing the fuse will do nothing. For more information, please visit my website at audioserviceclinic.com. You may contact me directly through the website.
Feb 06, 2014 | Bose 3 2 1 GS Series II DVD Home...
Electrical outlets don't work
if its a radial cicuit the outlet is in a chain and the ones that are not working follow on from this so recheck the cables are remade off back to fresh metal replaced back into the correct places and are nice and tight,dont forget to safely isolate before you do the work
Feb 23, 2013 | Dryers
Which subwoofer will sound the loudest?
When you're looking for a loud subwoofer you'll need to consider sensitivity, enclosure type and available power. You'll need to start with a subwoofer with a high efficiency (sensitivity) rating housed in a ported or band pass box.
Power the sub with an amplifier that has a power output that is within your sub's recommended power range. You'll achieve the slam you're listening for. Using an amplifier with a bass boost control can also help.
Jul 29, 2012 | Furniture
There is no power to the speaker, the green light is not showing. We have changed the plug fuse but this was not the problem
If you're talking about a powered subwoofer pluged into an electrical wall outlet check the wall outlet. One of my kids could not get a lamp to turn on in the den. It turned out the outlet was switched off from accross the room by a wall light switch. To check your electric wall outlet, plug in something, like a lamp, fan or a clock and see if it turns on. If not, look for wall light switches and flip them on and off. If it (example fan) dosn't turn on, you have a problem with your house electrical system. Probably right there at that outlet.
Sep 08, 2011 | Revel Audio Players & Recorders
My WHARFEDALE DIAMOND SW150 SUBWOOFER does not work. the light (red) comes on when connected. but no sound. I've tried direct from speaker and from receiver connection. doesn't work. Any advice
After finally finding the circuit diagram for the Wharfedale SW-150 sub woofer, I've managed to identify and fix a fault which has the same symptoms as yours.
The problem was with the largest of the two relays (Relay 1 in the attached photo).
The circuit has two power rectifiers, the first rectifier provides the small current for the system to operate in standby. Relay 1 is normally closed and this turns on the secondary power rectifier that powers the amplification circuit.
Relay 2 (smaller and black) is used to prevent the speaker from popping every time the auto-power switches on/off, it uses a delay to allow the amplifier to stabilize before activating the relay which connects the amplifier to the speaker.
On my system the power LED was lit, but the little click that happened about 2 seconds after power-on, was no longer heard. The little click that was missing is the sound of the smaller relay connecting the speaker. This relay was not activating because the amplification circuit had not been powered.
The larger relay does not need to activate to turn on the amplifier, as it is normally closed, meaning the the default connection state is to provide power to the amplifier. The relay is only used to disconnect the amplifier when the auto-off feature kicks in (or the system over heats). I could test this relay was clicking by connecting pins 1 and 3 on the temperature switch connector.
So the relay was not connecting properly in the closed state. This is what the relay looked like on the inside.
Mar 16, 2011 | Wharfedale SW150 Subwoofer
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
Velodyne DLS-3750 Subwoofer Logo
148 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Matthew Spark
Matthew Spark
Jerry Greenberg
Jerry Greenberg
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
